Salta al contenuto principale
Repairing Lenovo R61i fan assembly replacement or cleaning
Cosa ti serve
  1. Repairing Lenovo R61i fan assembly replacement or cleaning, fan assembly: passo 1, immagine 1 di 3 Repairing Lenovo R61i fan assembly replacement or cleaning, fan assembly: passo 1, immagine 2 di 3 Repairing Lenovo R61i fan assembly replacement or cleaning, fan assembly: passo 1, immagine 3 di 3
    • identify the exact type of your ThinkPad
    • get the right fan assembly, in this case FRU P/N: 42W2779
    • disconnect power-supply
    • detach battery
  2. Repairing Lenovo R61i fan assembly replacement or cleaning: passo 2, immagine 1 di 2 Repairing Lenovo R61i fan assembly replacement or cleaning: passo 2, immagine 2 di 2
    • find all five screws with the shown symbols and unscrew them
  3. Repairing Lenovo R61i fan assembly replacement or cleaning: passo 3, immagine 1 di 2 Repairing Lenovo R61i fan assembly replacement or cleaning: passo 3, immagine 2 di 2
    • unscrew all the shown screws
    • These ones are tiny
    • watch the sizes of the screws
  4. Repairing Lenovo R61i fan assembly replacement or cleaning: passo 4, immagine 1 di 2 Repairing Lenovo R61i fan assembly replacement or cleaning: passo 4, immagine 2 di 2
    • remove the palm rest carefully
    • If you have a touchpad or fingerprint reader watch the cables
    • blow the dust away
  5. Repairing Lenovo R61i fan assembly replacement or cleaning: passo 5, immagine 1 di 3 Repairing Lenovo R61i fan assembly replacement or cleaning: passo 5, immagine 2 di 3 Repairing Lenovo R61i fan assembly replacement or cleaning: passo 5, immagine 3 di 3
    • lift the keyboard carefully
    • watch the cable
    • Use a spudger to detach the cable
    • lift the keyboad and leave it on the side
  6. Repairing Lenovo R61i fan assembly replacement or cleaning: passo 6, immagine 1 di 3 Repairing Lenovo R61i fan assembly replacement or cleaning: passo 6, immagine 2 di 3 Repairing Lenovo R61i fan assembly replacement or cleaning: passo 6, immagine 3 di 3
    • just for reference: images showing the keyboard-connector
  7. Repairing Lenovo R61i fan assembly replacement or cleaning: passo 7, immagine 1 di 2 Repairing Lenovo R61i fan assembly replacement or cleaning: passo 7, immagine 2 di 2
    • unscrew the left and right screw of the keyboard bezel and speakers
  8. Repairing Lenovo R61i fan assembly replacement or cleaning: passo 8, immagine 1 di 2 Repairing Lenovo R61i fan assembly replacement or cleaning: passo 8, immagine 2 di 2
    • unscrew the first two screws of the shielding
  9. Repairing Lenovo R61i fan assembly replacement or cleaning: passo 9, immagine 1 di 3 Repairing Lenovo R61i fan assembly replacement or cleaning: passo 9, immagine 2 di 3 Repairing Lenovo R61i fan assembly replacement or cleaning: passo 9, immagine 3 di 3
    • carefully lift the wireless antenna cable from the cable guide
    • unscrew the last two screws from the keyboard bezel
  10. Repairing Lenovo R61i fan assembly replacement or cleaning: passo 10, immagine 1 di 2 Repairing Lenovo R61i fan assembly replacement or cleaning: passo 10, immagine 2 di 2
    • watch the claws of the bezel (Sorry, no image!)
    • carefully pull out the keyboard bezel
    • flip the bezel 180°
    • watch the cables
  11. Repairing Lenovo R61i fan assembly replacement or cleaning: passo 11, immagine 1 di 1
    • remove the wireless antenna cable from the cable guide of the fan assembly
    • you might want to use a metal spudger to widen the cable guide if necessary
  12. Repairing Lenovo R61i fan assembly replacement or cleaning: passo 12, immagine 1 di 2 Repairing Lenovo R61i fan assembly replacement or cleaning: passo 12, immagine 2 di 2
    • unscrew the fist, tiny screw of the clip
    • unscrew the longer screw of the clip
    • remove the clip
  13. Repairing Lenovo R61i fan assembly replacement or cleaning: passo 13, immagine 1 di 2 Repairing Lenovo R61i fan assembly replacement or cleaning: passo 13, immagine 2 di 2
    • remove the shorter screw of the second clip
    • remove the longer screw of the second clip
    • remove the clip
  14. Repairing Lenovo R61i fan assembly replacement or cleaning: passo 14, immagine 1 di 2 Repairing Lenovo R61i fan assembly replacement or cleaning: passo 14, immagine 2 di 2
    • remove the last two screws of the fan assembly
    • detach the power cord with a spudger
  15. Repairing Lenovo R61i fan assembly replacement or cleaning: passo 15, immagine 1 di 2 Repairing Lenovo R61i fan assembly replacement or cleaning: passo 15, immagine 2 di 2
    • CPU with thermal grease
    • other chip with termal grease
    • carfully lift the fan assembly
    • you may need to pull a little more because of the thermal grease
  16. Repairing Lenovo R61i fan assembly replacement or cleaning: passo 16, immagine 1 di 2 Repairing Lenovo R61i fan assembly replacement or cleaning: passo 16, immagine 2 di 2
    • take a spudger and remove the old thermal grease
  17. Repairing Lenovo R61i fan assembly replacement or cleaning: passo 17, immagine 1 di 2 Repairing Lenovo R61i fan assembly replacement or cleaning: passo 17, immagine 2 di 2
    • get a paper-wiper
    • wrap the wiper around the spudger
  18. Repairing Lenovo R61i fan assembly replacement or cleaning: passo 18, immagine 1 di 2 Repairing Lenovo R61i fan assembly replacement or cleaning: passo 18, immagine 2 di 2
    • get some alcohol on the wiper
    • clean the CPU with the wiper
    • clean the chip with the wiper
    • Ensure there is no old thermal grease left
    • Follow this guide to add new thermal paste to the CPU.
  19. Repairing Lenovo R61i fan assembly replacement or cleaning: passo 19, immagine 1 di 3 Repairing Lenovo R61i fan assembly replacement or cleaning: passo 19, immagine 2 di 3 Repairing Lenovo R61i fan assembly replacement or cleaning: passo 19, immagine 3 di 3
    • now place the new fan assembly
    • pay attention to the thermal grease on the backside of your new fan assembly
    • press down the CPU- and chip-connector
    • don't forget to plugin the power cable of the fan assembly
Conclusione
Altre 6 persone hanno completato questa guida.
Dennis
Membro da: 01/06/13
311 Reputazione
1 Guida realizzata
2 Commenti
This worked perfectly for a couple of my IBM Lenovo R61s. It was spot on except in step 3 you need to remove both screws by the red circles in order to the get inside bezel off, for the R61 anyway. Thanks for the great tutorial!
tech4eleven - Replica
Excellent guide! It took me less than 1 hour to complete all the steps, and get my R61 up and running again! Thanks a lot
Ioannis Kolaxis - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 26
Tutti i Tempi: 19,489
