Salta al contenuto principale
Rear Axle Removal
Solo Prerequisita
Questa è una guida che contiene solo i prerequisiti! Questa guida fa parte di un'altra procedura e non è destinata ad essere utilizzata da sola.
Cosa ti serve
  1. Rear Axle Removal, Disconnect the spark plug wire: passo 1, immagine 1 di 2 Rear Axle Removal, Disconnect the spark plug wire: passo 1, immagine 2 di 2
    • Before you begin, ensure that the mower is powered down and cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
  2. Rear Axle Removal, Chock the rear wheels: passo 2, immagine 1 di 1
    • Chock the rear wheels to prevent the mower from rolling during service.
    • If the blades are extremely dirty, you can clean them using the washout fitting so the bolts on the underside of the blade guard are accessible.
  3. Rear Axle Removal, Lift up the deflector: passo 3, immagine 1 di 2 Rear Axle Removal, Lift up the deflector: passo 3, immagine 2 di 2
    • Lift up the plastic deflector.
  4. Rear Axle Removal, Remove the grass bag: passo 4, immagine 1 di 3 Rear Axle Removal, Remove the grass bag: passo 4, immagine 2 di 3 Rear Axle Removal, Remove the grass bag: passo 4, immagine 3 di 3
    • While holding the deflector up and out of the way, lift the grass bag handle away from the mower to detach it.
    • Remove the grass bag.
  5. Rear Axle Removal, Set the height adjustment lever: passo 5, immagine 1 di 1
    • Set the height adjustment lever all the way forward, past the "A" setting, to loosen the axle spring underneath the mower.
  6. Rear Axle Removal, Tilt the mower on its side: passo 6, immagine 1 di 1
    • Tilt the mower onto its side so the blades are facing out.
    • This may require two people.
  7. Rear Axle Removal, Unhook the axle spring: passo 7, immagine 1 di 3 Rear Axle Removal, Unhook the axle spring: passo 7, immagine 2 di 3 Rear Axle Removal, Unhook the axle spring: passo 7, immagine 3 di 3
    • Reach underneath the axle, near the transmission, and pull the axle spring out towards the axle and down to unhook it.
    • Return the mower back to an upright position.
  8. Rear Axle Removal, Block up the mower: passo 8, immagine 1 di 2 Rear Axle Removal, Block up the mower: passo 8, immagine 2 di 2
    • Place the mower on blocks so each wheel is above the work surface and can rotate freely.
  9. Rear Axle Removal, Remove the wheel: passo 9, immagine 1 di 1
    • Use a 9/16 inch socket to remove the wheel nut.
  10. Rear Axle Removal: passo 10, immagine 1 di 2 Rear Axle Removal: passo 10, immagine 2 di 2
    • Remove the wheel.
  11. Rear Axle Removal, Remove the axle components: passo 11, immagine 1 di 2 Rear Axle Removal, Remove the axle components: passo 11, immagine 2 di 2
    • Remove the wheel washer.
  12. Rear Axle Removal: passo 12, immagine 1 di 3 Rear Axle Removal: passo 12, immagine 2 di 3 Rear Axle Removal: passo 12, immagine 3 di 3
    • Remove the dust cover.
  13. Rear Axle Removal: passo 13, immagine 1 di 3 Rear Axle Removal: passo 13, immagine 2 di 3 Rear Axle Removal: passo 13, immagine 3 di 3
    • Use a pair of needle nose pliers to remove the gear retaining pin.
  14. Rear Axle Removal: passo 14, immagine 1 di 3 Rear Axle Removal: passo 14, immagine 2 di 3 Rear Axle Removal: passo 14, immagine 3 di 3
    • Remove the drive gear.
  15. Rear Axle Removal: passo 15, immagine 1 di 3 Rear Axle Removal: passo 15, immagine 2 di 3 Rear Axle Removal: passo 15, immagine 3 di 3
    • Use a pair of snap ring pliers to remove the snap ring from the driveline.
  16. Rear Axle Removal: passo 16, immagine 1 di 1
    • Remove the snap ring washer.
  17. Rear Axle Removal: passo 17, immagine 1 di 1
    • Use a 1/2 inch socket to remove the driveline bearing retaining bolt.
  18. Rear Axle Removal: passo 18, immagine 1 di 3 Rear Axle Removal: passo 18, immagine 2 di 3 Rear Axle Removal: passo 18, immagine 3 di 3
    • Firmly pull the driveline bearing away from the mower.
    • This bearing is holding the driveline in place, so some components may shift around during removal.
    • This may require some force.
    • Repeat the last nine steps for the right side of the mower, starting with removing the right wheel. Once complete, continue to the next step.
  19. Rear Axle Removal, Remove the height adjustment lever: passo 19, immagine 1 di 2 Rear Axle Removal, Remove the height adjustment lever: passo 19, immagine 2 di 2
    • Remove the height adjustment lever from the left side of the mower.
  20. Rear Axle Removal, Remove the axle: passo 20, immagine 1 di 3 Rear Axle Removal, Remove the axle: passo 20, immagine 2 di 3 Rear Axle Removal, Remove the axle: passo 20, immagine 3 di 3
    • Holding the left end of the axle with your left hand and the right end of the driveline with your right hand, firmly pull them in opposite directions—the axle to the left, and the driveline to the right.
    • While maintaining these opposing forces, squeeze both axles together.
  21. Rear Axle Removal: passo 21, immagine 1 di 2 Rear Axle Removal: passo 21, immagine 2 di 2
    • With the axle being pulled left and driveline being pulled right, force the left end of the axle out and down, around the end of the driveline.
    • If done correctly, there will be enough of a gap for the axle to clear the end of the driveline and drop down towards the work surface.
  22. Rear Axle Removal: passo 22, immagine 1 di 2 Rear Axle Removal: passo 22, immagine 2 di 2
    • Remove the axle.
Linea Traguardo
Carsten Frauenheim
Membro da: 03/10/20
158.491 Reputazione
439 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
24.036 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 13
Tutti i Tempi: 61
