Salta al contenuto principale
RazorX DLX Electric Skateboard Wheel and Bearing Replacement
Cosa ti serve
  1. RazorX DLX Electric Skateboard Wheel and Bearing Replacement, Wheel and Bearing: passo 1, immagine 1 di 3 RazorX DLX Electric Skateboard Wheel and Bearing Replacement, Wheel and Bearing: passo 1, immagine 2 di 3 RazorX DLX Electric Skateboard Wheel and Bearing Replacement, Wheel and Bearing: passo 1, immagine 3 di 3
    • Flip the skateboard onto its side.
    • Use a 13 mm socket wrench to remove the nut that holds the wheel onto the trucks.
    • Pull the wheel off.
    • There will be a small washer between the nut and the bearing; make sure you don't lose it.
  2. RazorX DLX Electric Skateboard Wheel and Bearing Replacement: passo 2, immagine 1 di 3 RazorX DLX Electric Skateboard Wheel and Bearing Replacement: passo 2, immagine 2 di 3 RazorX DLX Electric Skateboard Wheel and Bearing Replacement: passo 2, immagine 3 di 3
    • Set the nut and washers aside.
    • Remove the bearings and spacer by pushing/prying them out against the trucks.
    • Place the tip of the truck into the bearing, firmly grip the wheel, push down and rotate outward to remove each bearing. Keep track of the spacer that is in between the bearings during removal.
  3. RazorX DLX Electric Skateboard Wheel and Bearing Replacement: passo 3, immagine 1 di 2 RazorX DLX Electric Skateboard Wheel and Bearing Replacement: passo 3, immagine 2 di 2
    • Insert one bearing into your replacement wheel.
    • Place the spacer centered onto that bearing and insert the second bearing on top of it.
    • The bearings should fit snugly in place.
  4. RazorX DLX Electric Skateboard Wheel and Bearing Replacement: passo 4, immagine 1 di 2 RazorX DLX Electric Skateboard Wheel and Bearing Replacement: passo 4, immagine 2 di 2
    • See the first photo for the order of reassembly.
    • Place one washer onto the trucks first.
    • Place the wheel with your bearings in place onto the trucks, with the face of the wheel outward.
    • Place the next washer on the trucks.
    • Place the nut on the trucks, and tighten using a 13mm socket wrench.
    • Do not over tighten the nut. The wheel should spin freely and smoothly.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Cuesta, Team 20-4, Krynen Fall 2024 Membro di Cuesta, Team 20-4, Krynen Fall 2024
CUESTA-KRYNEN-F24S20G4
5 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 46
