Introduzione
This guide is intended to show you how to replace the trucks on a RazorX DLX Electric Skateboard. This guide can be used for other standard skateboards as well. The trucks on a skateboard connect the board to the wheels and also house the bushings. Having damaged trucks can make the skateboard unsafe to use. Before you start, make sure the power button is switched to off.
Cosa ti serve
Flip the skateboard onto its side.
Use a 13 mm socket wrench to remove the nut that holds the wheel onto the trucks.
Pull the wheel off.
See the first photo for the order of reassembly.
Place one washer onto the trucks first.
Place the wheel with your bearings in place onto the trucks, with the face of the wheel outward.
Place the next washer on the trucks.
Place the nut on the trucks, and tighten using a 13mm socket wrench.
Orient the skateboard so that you have access to the four 32 mm bolts and the nuts that hold them in place,
Remove the four 32 mm bolts with a 3 mm Allen key while holding the nut in place.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
