Salta al contenuto principale
Razer DeathAdder V2 Pro Battery Replacement
Cosa ti serve
  1. Razer DeathAdder V2 Pro Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the mouse over so that the writing on the bottom faces up.
  2. Razer DeathAdder V2 Pro Battery Replacement: passo 2, immagine 1 di 1
    • Use a spudger to remove the three pads on the bottom of the mouse.
  3. Razer DeathAdder V2 Pro Battery Replacement: passo 3, immagine 1 di 2 Razer DeathAdder V2 Pro Battery Replacement: passo 3, immagine 2 di 2
    • Remove the four 1.2 mm screws from each corner of the mouse using a T6 Torx screwdriver.
  4. Razer DeathAdder V2 Pro Battery Replacement: passo 4, immagine 1 di 1
    • Use a nylon spudger to pry the back cover away from the mouse.
    • Starting from the lower corner of the mouse is strongly recommended. Once the tool is in, slide it in between the top and the lower part of the mouse, and run it around the edge of the bottom cover until it pops out naturally.
    • Be cautious not to crack the top and the bottom covers of the mouse.
  5. Razer DeathAdder V2 Pro Battery Replacement: passo 5, immagine 1 di 1
    • Detach the white connector with red wires gently from the side that connects the side buttons to the PCB.
    • Be careful not to pull too hard on the connector to avoid damaging the solder that connects to the PCB.
  6. Razer DeathAdder V2 Pro Battery Replacement: passo 6, immagine 1 di 1
    • Make sure the PCB is disconnected as shown before pulling apart the two halves of the mouse.
  7. Razer DeathAdder V2 Pro Battery Replacement: passo 7, immagine 1 di 1
    • Place both the top and bottom pieces of the mouse on their backs.
  8. Razer DeathAdder V2 Pro Battery Replacement: passo 8, immagine 1 di 1
    • Remove the three 1 mm screws that hold the battery to the circuit board using a Phillips #1 screwdriver.
    • Remove the battery from the mouse.
Conclusione
Tatiana Nzeba
Membro da: 09/15/22
160 Reputazione
1 Guida realizzata
3 Commenti
What Voltage and mAh is the battery?
Nicoolodion - Replica
AliExpress ex. has the apropriate battery for this mouse.
It´s a battery with 1500mAh and 3,7V .
Claus Gärtner - Replica
Are you referring to LOSONCOER?
pikimouse -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 96
Ultimi 30 Giorni: 319
Tutti i Tempi: 3,666
