Salta al contenuto principale
Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement
Cosa ti serve
  1. Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement, Back Panel: passo 1, immagine 1 di 2 Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement, Back Panel: passo 1, immagine 2 di 2
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement: passo 2, immagine 1 di 2 Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement: passo 2, immagine 2 di 2
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement, Wi-Fi Card: passo 3, immagine 1 di 2 Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement, Wi-Fi Card: passo 3, immagine 2 di 2
    • Flip up the black plastic lock-bar on the ZIF connector, then gently pull the ribbon cable directly out of its motherboard port.
  4. Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement: passo 4, immagine 1 di 2 Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement: passo 4, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the single 3 mm screw from the upper-right corner of the Wi-Fi card.
  5. Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement: passo 5, immagine 1 di 2 Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement: passo 5, immagine 2 di 2
    • Slide an ESD-safe tool under the black and gray coaxial cable connections, and gently lift the plugs vertically to disconnect them from the Wi-Fi card.
    • Grip the Wi-Fi card from both sides and pull it directly out of its port.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 364
