Salta al contenuto principale
RCA RCT6773W22 Speaker Replacement
Cosa ti serve
  1. RCA RCT6773W22 Speaker Replacement, Battery: passo 1, immagine 1 di 2 RCA RCT6773W22 Speaker Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the two 5mm screws from the bottom of the device using a Phillips #000 screwdriver.
  2. RCA RCT6773W22 Speaker Replacement: passo 2, immagine 1 di 3 RCA RCT6773W22 Speaker Replacement: passo 2, immagine 2 di 3 RCA RCT6773W22 Speaker Replacement: passo 2, immagine 3 di 3
    • Place the plastic opening tool between the case and the screen.
    • Slide the tool clockwise around the case until all the clips are removed.
    • Do not completely separate the case from the screen because there is a wire connecting the motherboard to the speaker.
  3. RCA RCT6773W22 Speaker Replacement: passo 3, immagine 1 di 3 RCA RCT6773W22 Speaker Replacement: passo 3, immagine 2 di 3 RCA RCT6773W22 Speaker Replacement: passo 3, immagine 3 di 3
    • Desolder the two wires that connect the battery to the motherboard.
    • Learn more about soldering with this soldering technique guide.
    • Using the blue plastic opening tool, lift the battery away from the device.
  4. RCA RCT6773W22 Speaker Replacement, Speaker: passo 4, immagine 1 di 3 RCA RCT6773W22 Speaker Replacement, Speaker: passo 4, immagine 2 di 3 RCA RCT6773W22 Speaker Replacement, Speaker: passo 4, immagine 3 di 3
    • Desolder the wire connected from the speaker to the motherboard.
    • Pry the speaker from the casing with a plastic opening tool.
Conclusione
Kelsea Weber
Membro da: 11/12/15
19.880 Reputazione
32 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
17.277 Guide realizzate
Un commento
Where can I buy a replacement speaker?
laubd - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,095
