Introduzione
In this guide, you will learn how to replace the rear camera on your device.
Cosa ti serve
Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
Use a soldering iron to remove the soldered connections on the motherboard
Using a spudger, gently pry off the camera from the back of the display
Quasi finito!
Conclusione
