Salta al contenuto principale
RCA RCT6272W23 Motherboard Replacement
Cosa ti serve
  1. RCA RCT6272W23 Motherboard Replacement, Case: passo 1, immagine 1 di 2 RCA RCT6272W23 Motherboard Replacement, Case: passo 1, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
  2. RCA RCT6272W23 Motherboard Replacement: passo 2, immagine 1 di 2 RCA RCT6272W23 Motherboard Replacement: passo 2, immagine 2 di 2
    • Press the plastic opening tool into the space between the front and back portions of the case.
    • Run it along the perimeter of the device to unhook the plastic tabs.
    • Gently pull both sides apart.
    • The speaker is connected to the back cover, so be careful when separating.
  3. RCA RCT6272W23 Motherboard Replacement, Motherboard: passo 3, immagine 1 di 3 RCA RCT6272W23 Motherboard Replacement, Motherboard: passo 3, immagine 2 di 3 RCA RCT6272W23 Motherboard Replacement, Motherboard: passo 3, immagine 3 di 3
    • Use a soldering iron to remove the soldered connections on the motherboard
    • For your safety and to ensure a correct repair, be sure to exercise caution when using the soldering iron.
    • For more information about soldering, check out this guide.
  4. RCA RCT6272W23 Motherboard Replacement: passo 4, immagine 1 di 1
    • Use a philips #00 screwdriver to unscrew the three 4.064mm screws which attach the motherboard to the front of the device.
  5. RCA RCT6272W23 Motherboard Replacement: passo 5, immagine 1 di 2 RCA RCT6272W23 Motherboard Replacement: passo 5, immagine 2 di 2
    • Use your fingers to pop the three black tabs up to release the flat plastic data transfer cables.
  6. RCA RCT6272W23 Motherboard Replacement: passo 6, immagine 1 di 1
    • Pull up the motherboard from the rest of the body.
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
i need to know everything there is about the motherboard. an tablet. images, info etc
Paul Shreves - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,126
