Salta al contenuto principale
RCA RCT6272W23 Display Replacement
Cosa ti serve
  1. RCA RCT6272W23 Display Replacement, Case: passo 1, immagine 1 di 2 RCA RCT6272W23 Display Replacement, Case: passo 1, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
  2. RCA RCT6272W23 Display Replacement: passo 2, immagine 1 di 2 RCA RCT6272W23 Display Replacement: passo 2, immagine 2 di 2
    • Press the plastic opening tool into the space between the front and back portions of the case.
    • Run it along the perimeter of the device to unhook the plastic tabs.
    • Gently pull both sides apart.
    • The speaker is connected to the back cover, so be careful when separating.
  3. RCA RCT6272W23 Display Replacement, Motherboard: passo 3, immagine 1 di 3 RCA RCT6272W23 Display Replacement, Motherboard: passo 3, immagine 2 di 3 RCA RCT6272W23 Display Replacement, Motherboard: passo 3, immagine 3 di 3
    • Use a soldering iron to remove the soldered connections on the motherboard
    • For your safety and to ensure a correct repair, be sure to exercise caution when using the soldering iron.
    • For more information about soldering, check out this guide.
  4. RCA RCT6272W23 Display Replacement: passo 4, immagine 1 di 1
    • Use a philips #00 screwdriver to unscrew the three 4.064mm screws which attach the motherboard to the front of the device.
  5. RCA RCT6272W23 Display Replacement: passo 5, immagine 1 di 2 RCA RCT6272W23 Display Replacement: passo 5, immagine 2 di 2
    • Use your fingers to pop the three black tabs up to release the flat plastic data transfer cables.
  6. RCA RCT6272W23 Display Replacement: passo 6, immagine 1 di 1
    • Pull up the motherboard from the rest of the body.
  7. RCA RCT6272W23 Display Replacement, Display: passo 7, immagine 1 di 1
    • Using a plastic opening tool, pry the battery off of the rest of the body.
    • The battery is attached to the display with double sided tape. It may be best to have a new strip of double sided tape to reattach the battery.
  8. RCA RCT6272W23 Display Replacement: passo 8, immagine 1 di 3 RCA RCT6272W23 Display Replacement: passo 8, immagine 2 di 3 RCA RCT6272W23 Display Replacement: passo 8, immagine 3 di 3
    • Using a spudger, separate the display surface from the front cover.
    • Be careful not to break the tabs that hold the display screen in place.
    • A second spudger may be necessary to help hold the position of the display screen.
Conclusione
Altre 4 persone hanno completato questa guida.
Ross Pennala
Membro da: 03/19/15
214 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 2,421
