Salta al contenuto principale
RCA RCT6272W23 Battery Replacement
Cosa ti serve
  1. RCA RCT6272W23 Battery Replacement, Case: passo 1, immagine 1 di 2 RCA RCT6272W23 Battery Replacement, Case: passo 1, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
  2. RCA RCT6272W23 Battery Replacement: passo 2, immagine 1 di 2 RCA RCT6272W23 Battery Replacement: passo 2, immagine 2 di 2
    • Press the plastic opening tool into the space between the front and back portions of the case.
    • Run it along the perimeter of the device to unhook the plastic tabs.
    • Gently pull both sides apart.
    • The speaker is connected to the back cover, so be careful when separating.
  3. RCA RCT6272W23 Battery Replacement, Battery: passo 3, immagine 1 di 1
    • Use a soldering iron to remove the soldered connections from the battery to the motherboard.
    • For your safety, and to ensure a correct repair, be sure to exercise caution when using the soldering iron.
    • For more information about soldering, check out this guide.
  4. RCA RCT6272W23 Battery Replacement: passo 4, immagine 1 di 1
    • Next, use the spudger to pry the battery off of the rest of the body.
    • The battery is taped on with double-sided tape. Prepare another strip of double-sided tape and have it ready to reattach the battery.
Conclusione
Altre 4 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 5,340
