Salta al contenuto principale
RCA 8 Apollo Display Assembly Replacement
Cosa ti serve
  1. RCA 8 Apollo Display Assembly Replacement, Back Panel: passo 1, immagine 1 di 1
    • Before you begin, discharge your tablet battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your tablet before beginning to disassemble.
  2. RCA 8 Apollo Display Assembly Replacement: passo 2, immagine 1 di 2 RCA 8 Apollo Display Assembly Replacement: passo 2, immagine 2 di 2
    • Insert an iFixit opening tool into the gap between the tablet and back panel.
    • Using a combination of iFixit opening tools and iFixit opening picks, pry the tablet upward around its perimeter to release it from the plastic rear case.
    • If inserted too far, an opening pick can damage your device. It is helpful to mark the edge with an opening pick, or opening tool at a depth that will not damage the inner contents of the tablet.
  3. RCA 8 Apollo Display Assembly Replacement: passo 3, immagine 1 di 2 RCA 8 Apollo Display Assembly Replacement: passo 3, immagine 2 di 2
    • Disconnect the red and black speaker wires from the tablet.
    • The front and back of the tablet will be disconnected.
  4. RCA 8 Apollo Display Assembly Replacement, Display Assembly: passo 4, immagine 1 di 3 RCA 8 Apollo Display Assembly Replacement, Display Assembly: passo 4, immagine 2 di 3 RCA 8 Apollo Display Assembly Replacement, Display Assembly: passo 4, immagine 3 di 3
    • Release the gold and black tab from the battery that's attached to a gray wire. The gold tab is held down by an adhesive; pull it until the adhesive releases.
    • Remove the yellow tape that is around the battery.
    • Unlock the ZIF socket and detach the display data interconnect cable from the front panel assembly.
    • If the connector is misaligned, the pins can bend, causing permanent damage.
  5. RCA 8 Apollo Display Assembly Replacement: passo 5, immagine 1 di 1
    • Remove the three screws from the motherboard using a Phillips screwdriver.
  6. RCA 8 Apollo Display Assembly Replacement: passo 6, immagine 1 di 1
    • Remove the battery and motherboard together from the tablet.
    • If the tablet needs a battery replacement, disconnect the battery and replace it with a new one.
    • The battery might be glued down; you will just need to slowly remove the battery as the adhesive releases.
Conclusione
Kristen Gismondi
Membro da: 11/12/14
100.201 Reputazione
258 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
23.758 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 82
