Salta al contenuto principale
Puritan Bennett 840 BPS Battery Replacement
Attrezzature medicali
Né iFixit né questa guida di riparazione sono approvati dal produttore del dispositivo medicale o affiliati ad esso.
  1. Puritan Bennett 840 BPS Battery Replacement, BPS Battery: passo 1, immagine 1 di 2 Puritan Bennett 840 BPS Battery Replacement, BPS Battery: passo 1, immagine 2 di 2
    • Before beginning, ensure that the battery is drained and the ventilator is not connected to a power source.
    • Locate the breath delivery unit (BDU) shelf on the ventilator.
    • Locate the battery indicator label on the shelf to determine whether the BPS battery holds a one-hour or four-hour charge - the default for this guide is a four-hour battery.
  2. Puritan Bennett 840 BPS Battery Replacement: passo 2, immagine 1 di 1
    • Grasp the sides of the front bezel of the BPU and gently spread them away from the ventilator.
    • Pull the bezel outward to remove it from the cart.
    • Use a Phillips screwdriver to remove the two screws that connect the BPS to the BDU shelf at the back of the cart.
  3. Puritan Bennett 840 BPS Battery Replacement: passo 3, immagine 1 di 1
    • Using a Phillips screwdriver, remove the eleven screws securing the BPS top and front metal covers.
    • If the BPS contains a one-hour battery, only the four screws holding the one-hour battery shield (four on the top cover) need to be removed.
    • Pull the covers away from the BPS.
  4. Puritan Bennett 840 BPS Battery Replacement: passo 4, immagine 1 di 3 Puritan Bennett 840 BPS Battery Replacement: passo 4, immagine 2 di 3 Puritan Bennett 840 BPS Battery Replacement: passo 4, immagine 3 di 3
    • Locate the battery indicator bracket.
    • Cut the zip tie connecting the battery harness (bundle of wires coming from the battery) to the battery indicator bracket.
    • If the ventilator contains a one-hour battery, simply disconnect the battery harness from the battery cable and lift the battery out of the BPS.
  5. Puritan Bennett 840 BPS Battery Replacement: passo 5, immagine 1 di 1
    • Use a Phillips screwdriver to remove the two screws securing the battery retaining bracket to the rear of the BPS.
  6. Puritan Bennett 840 BPS Battery Replacement: passo 6, immagine 1 di 1
    • Disconnect the battery connector from J2 on the circuit board next to the battery indicator bracket.
  7. Puritan Bennett 840 BPS Battery Replacement: passo 7, immagine 1 di 1
    • Using a Phillips screwdriver, loosen the two side screws and the two base screws holding the BPS front bracket.
    • Carefully lift the battery out of the BPS.
Conclusione
Altre 2 persone hanno completato questa guida.
Olivia May
Membro da: 01/23/20
606 Reputazione
1 Guida realizzata
Cal Poly, Team S7-G4, Paton Spring 2020 Membro di Cal Poly, Team S7-G4, Paton Spring 2020
CPSU-PATON-S20S7G4
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,038
