Salta al contenuto principale
Protocol Videodrone AP Propeller Motors Replacement
Cosa ti serve
  1. Protocol Videodrone AP Propeller Motors Replacement, Propeller Motors: passo 1, immagine 1 di 1
    • Power off the drone before proceeding with the rest of the guide.
  2. Protocol Videodrone AP Propeller Motors Replacement: passo 2, immagine 1 di 1
    • Use the Phillips #0 screwdriver to remove four propeller screws.
    • If you don't own the screwdriver included with the drone kit, use a Phillips #0 screwdriver.
  3. Protocol Videodrone AP Propeller Motors Replacement: passo 3, immagine 1 di 2 Protocol Videodrone AP Propeller Motors Replacement: passo 3, immagine 2 di 2
    • Use the Phillips #0 screwdriver to remove eight propeller guard screws.
  4. Protocol Videodrone AP Propeller Motors Replacement: passo 4, immagine 1 di 2 Protocol Videodrone AP Propeller Motors Replacement: passo 4, immagine 2 di 2
    • Use the Phillips #0 screwdriver to remove eight housing screws from the bottom of the drone.
  5. Protocol Videodrone AP Propeller Motors Replacement: passo 5, immagine 1 di 1
    • Open up housing to reveal main circuit board.
  6. Protocol Videodrone AP Propeller Motors Replacement: passo 6, immagine 1 di 2 Protocol Videodrone AP Propeller Motors Replacement: passo 6, immagine 2 di 2
    • Use the Phillips #0 screwdriver to remove three motor housing screws. There are three screws per motor.
    • The plastic housing is glued directly to motor.
  7. Protocol Videodrone AP Propeller Motors Replacement: passo 7, immagine 1 di 3 Protocol Videodrone AP Propeller Motors Replacement: passo 7, immagine 2 di 3 Protocol Videodrone AP Propeller Motors Replacement: passo 7, immagine 3 di 3
    • Desolder the wires connecting the propeller motor to the motherboard (2 per motor) and remove the motor from the device.
    • For more information on soldering connections, please visit the How to Solder and Desolder Connections guide.
Conclusione
Altre 2 persone hanno completato questa guida.
IUPUI, Team S2-G2, Harley Fall 2019 Membro di IUPUI, Team S2-G2, Harley Fall 2019
IUPUI-HARLEY-F19S2G2
3 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 266
