Introduzione
The TerraCopter Evo controller joysticks are used to guide and steer the drone in flight and on the ground. The joysticks can break off from the controller or separate from their assemblies. This guide will assist in opening the controller to the joysticks and completely replacing them. If your joysticks are just cosmetically damaged, you can just follow up to Step 2 and then reassemble with your new joysticks. However, if your joysticks are not processing input correctly or at all, you will need to solder to replace the electrical component. Check out our How to Solder and Desolder Connections guide if you are unfamiliar with soldering best practices.
Cosa ti serve
Using a Phillips #0 screwdriver, remove the screw connecting the battery cover to the controller.
Remove the battery cover from the controller.
Passo 3 Protocol TerraCopter EVO Controller Opening
Attenzione: i passaggi 3-4 provengono da una guida contrassegnata come in corso.
Orientate the controller to where the battery compartment is facing upwards.
Remove the four 5mm and four 4mm Phillips #1 screws from the case.
Remove the eight 5mm Phillips #1 screws from the motherboard.
