Salta al contenuto principale
Protocol TerraCopter EVO Drone Motor Replacement
Cosa ti serve
  1. Protocol TerraCopter EVO Drone Motor Replacement, Drone Motor: passo 1, immagine 1 di 1
    • Orientate the drone to where the black side of the drone face upwards.
    • On the bottom side of the drone, remove the twenty-two 5mm Phillips #1 screws holding the black frame to the body.
    • There is one screw under the rear light. Pry the opaque cover to access the last screw.
  2. Protocol TerraCopter EVO Drone Motor Replacement: passo 2, immagine 1 di 1
    • The plastic frames are subject to cracking.
    • Wires run through both frames.
    • Pry the white body away from the black frame.
  3. Protocol TerraCopter EVO Drone Motor Replacement: passo 3, immagine 1 di 1
    • Gently pry the motor from it's socket.
  4. Protocol TerraCopter EVO Drone Motor Replacement: passo 4, immagine 1 di 2 Protocol TerraCopter EVO Drone Motor Replacement: passo 4, immagine 2 di 2
    • Locate these solder points of the leads on the motherboard.
    • From the front of the drone, the left motor has red and blue leads.
    • From the front of the drone, the right motor has white and black leads.
    • Remove the leads from their points on the motherboard with a soldering iron, respective to each motor.
    • Check out our How to Solder and Desolder Connections guide if you are unfamiliar with soldering practices.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 202
