Salta al contenuto principale
Protocol Kaptur GPS Main Circuit Board Replacement
Cosa ti serve
  1. Protocol Kaptur GPS Main Circuit Board Replacement, Battery: passo 1, immagine 1 di 2 Protocol Kaptur GPS Main Circuit Board Replacement, Battery: passo 1, immagine 2 di 2
    • The battery is accessible through the back of the drone.
    • Press the tabs on both sides of the white stripe to pull the battery out.
  2. Protocol Kaptur GPS Main Circuit Board Replacement: passo 2, immagine 1 di 3 Protocol Kaptur GPS Main Circuit Board Replacement: passo 2, immagine 2 di 3 Protocol Kaptur GPS Main Circuit Board Replacement: passo 2, immagine 3 di 3
    • Remove the screws starting with the three smaller ones on the top part of the battery.
    • Remove the three screws on the other side.
    • There are two screws tucked under where the yellow circle is located. You will need to remove the other screws first before you get to these two.
    • There should be one 7 mm Phillips head screw, three 6 mm Phillips head screws, and four 5 mm Phillips head screws.
  3. Protocol Kaptur GPS Main Circuit Board Replacement: passo 3, immagine 1 di 2 Protocol Kaptur GPS Main Circuit Board Replacement: passo 3, immagine 2 di 2
    • Remove the top piece, and gently pry the two halves apart. Divide the sticker if necessary.
  4. Protocol Kaptur GPS Main Circuit Board Replacement: passo 4, immagine 1 di 2 Protocol Kaptur GPS Main Circuit Board Replacement: passo 4, immagine 2 di 2
    • The battery is now removable from its container.
    • During reassembly, make sure the outlet is returned to its holder and faces the correct direction.
  5. Protocol Kaptur GPS Main Circuit Board Replacement, Main Circuit Board: passo 5, immagine 1 di 2 Protocol Kaptur GPS Main Circuit Board Replacement, Main Circuit Board: passo 5, immagine 2 di 2
    • Remove the 4x 7mm screws on the top and bottom, and the 2x 5mm screws from the middle, then remove the back part of the housing.
    • Remove the two hidden screws at the bottom, and the white power button.
    • There will be 6x 7 mm Phillips head screws, and 2x 5 mm Phillips head screws.
  6. Protocol Kaptur GPS Main Circuit Board Replacement: passo 6, immagine 1 di 3 Protocol Kaptur GPS Main Circuit Board Replacement: passo 6, immagine 2 di 3 Protocol Kaptur GPS Main Circuit Board Replacement: passo 6, immagine 3 di 3
    • Unplug all the cords from the circuit boards.
    • Carefully slide the main body right off the arms.
  7. Protocol Kaptur GPS Main Circuit Board Replacement: passo 7, immagine 1 di 2 Protocol Kaptur GPS Main Circuit Board Replacement: passo 7, immagine 2 di 2
    • Remove the four 4mm Phillips screws.
    • Desolder all cords on the circuit board, and pull the board up and out.
    • It is important to keep track of where the leads came from. Red/Blue and Black/White pairings belong to motors, whereas Black/Red pairings belong to lights. The ports are labeled on the board.
Conclusione
UW Stout, Team S8-G6, Ogden Spring 2018 Membro di UW Stout, Team S8-G6, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G6
3 Membri
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 908
