Salta al contenuto principale
Propel Gyro-X On-Board Battery Pack Replacement
Cosa ti serve
  1. Propel Gyro-X On-Board Battery Pack Replacement, Bottom Propellor Blades: passo 1, immagine 1 di 1
    • Remove the two 5.0 mm Phillips #00 screws from the rotors.
    • The blades will fall off when the screws have been removed.
  2. Propel Gyro-X On-Board Battery Pack Replacement, Outer Shell: passo 2, immagine 1 di 1
    • Locate the nubs on either side of the helicopter.
  3. Propel Gyro-X On-Board Battery Pack Replacement: passo 3, immagine 1 di 1
    • Pull the body shell off of the nubs on both sides.
  4. Propel Gyro-X On-Board Battery Pack Replacement: passo 4, immagine 1 di 2 Propel Gyro-X On-Board Battery Pack Replacement: passo 4, immagine 2 di 2
    • Push the front of the nose back towards the tail of the helicopter.
    • Push down on the shell and pull it away from the body, so that both slots pass over the hooks on the bottom of the helicopter.
  5. Propel Gyro-X On-Board Battery Pack Replacement, On-Board Battery Pack: passo 5, immagine 1 di 1
    • Do not cut battery wires simultaneously because this will cause a short circuit. Due to the unrestricted flow of electricity, a short circuit could cause bodily harm.
    • Pull the battery off of the holder.
    • Cut each of the wires to the battery one at a time using a pair of wire cutters.
    • To replace the battery, you will need to strip both of the wires from the circuit, and both of the wires from the battery. You will then need to twist and solder both pairs of wires(red to red, black to black). You can find directions on soldering here.
Conclusione
Altre 4 persone hanno completato questa guida.
Jack Jenner
Membro da: 04/08/15
293 Reputazione
2 Guide realizzate
Cal Poly, Team 17-2, Forte Spring 2015 Membro di Cal Poly, Team 17-2, Forte Spring 2015
CPSU-FORTE-S15S17G2
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 3,121
