Salta al contenuto principale
ProntoTec Axius Motherboard Replacement
Cosa ti serve
  1. ProntoTec Axius Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Make sure the device is completely turned off before you begging taking it apart to avoid electrocution risks.
    • Place the tablet face-up on a flat table.
  2. ProntoTec Axius Motherboard Replacement: passo 2, immagine 1 di 1
    • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
    • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
  3. ProntoTec Axius Motherboard Replacement: passo 3, immagine 1 di 1
    • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
    • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
  4. ProntoTec Axius Motherboard Replacement: passo 4, immagine 1 di 2 ProntoTec Axius Motherboard Replacement: passo 4, immagine 2 di 2
    • Remove only the yellow tape that touches the motherboard
    • Be careful not to cut or damage the wires (red and black) that connect the battery to the motherboard.
  5. ProntoTec Axius Motherboard Replacement: passo 5, immagine 1 di 3 ProntoTec Axius Motherboard Replacement: passo 5, immagine 2 di 3 ProntoTec Axius Motherboard Replacement: passo 5, immagine 3 di 3
    • Use a Phillips screwdriver (PH00) to unscrew the two screws that connects the motherboard to the device
    • Be careful not to cut or damage the wires (red and black) that connect the motherboard to the battery.
  6. ProntoTec Axius Motherboard Replacement: passo 6, immagine 1 di 2 ProntoTec Axius Motherboard Replacement: passo 6, immagine 2 di 2
    • Using a soldering iron, desolder the contact points of the speaker, battery and screen on the motherboard
    • If soldering is new to you, check out this helpful guide on soldering and desoldering connections.
    • Use pliers to pull the wire from the board
  7. ProntoTec Axius Motherboard Replacement: passo 7, immagine 1 di 2 ProntoTec Axius Motherboard Replacement: passo 7, immagine 2 di 2
    • Using the spudger, disconnect the ribbon cable connecting the camera to the motherboard
  8. ProntoTec Axius Motherboard Replacement: passo 8, immagine 1 di 3 ProntoTec Axius Motherboard Replacement: passo 8, immagine 2 di 3 ProntoTec Axius Motherboard Replacement: passo 8, immagine 3 di 3
    • Using the spudger, push the black tabs towards the ribbon cable to unlock the ribbon cables that connect the screen to the motherboard.
    • Gently pull and remove the ribbon cables from the motherboard
  9. ProntoTec Axius Motherboard Replacement: passo 9, immagine 1 di 2 ProntoTec Axius Motherboard Replacement: passo 9, immagine 2 di 2
    • Using the flat side of the spudger, lift up the mother board to disconnect from the screen.
Conclusione
Estelle Hatem
Membro da: 10/20/16
156 Reputazione
1 Guida realizzata
UMass Dartmouth, Team 5-3, Martin Fall 2016 Membro di UMass Dartmouth, Team 5-3, Martin Fall 2016
UMASSD-MARTIN-F16S5G3
3 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 14
Tutti i Tempi: 398
