Salta al contenuto principale
PowerBook G3 Pismo Modem Replacement
Cosa ti serve
  1. PowerBook G3 Pismo Modem Replacement, Keyboard: passo 1, immagine 1 di 1
    • Turn the keyboard locking screw so that it is parallel to the space bar.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the track pad.
  2. PowerBook G3 Pismo Modem Replacement: passo 2, immagine 1 di 1
    • Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
    • The connector may be tight. Gently rock the connector from side to side while pulling directly upward to free it. You can use this technique on many of the cards and cables you'll be disconnecting.
    • Make sure you have removed the laptop battery and CD/DVD modules from the expansion bays before proceeding.
  3. PowerBook G3 Pismo Modem Replacement: passo 3, immagine 1 di 1
    • Your laptop should look approximately like this.
  4. PowerBook G3 Pismo Modem Replacement, Heat Shield: passo 4, immagine 1 di 1
    • Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
    • Lift the heat shield up and pull it toward you.
  5. PowerBook G3 Pismo Modem Replacement: passo 5, immagine 1 di 1
  6. PowerBook G3 Pismo Modem Replacement, Airport Card: passo 6, immagine 1 di 1
    • Skip this step if your computer does not have an Airport card installed.
    • Firmly grasp the plastic tab attached to the Airport card and pull up and then to the right.
    • The Airport card is still attached to the antenna cable, so don't just yank it out of the slot.
  7. PowerBook G3 Pismo Modem Replacement: passo 7, immagine 1 di 1
    • Disconnect the antenna cable from the Airport card.
  8. PowerBook G3 Pismo Modem Replacement, PRAM Battery: passo 8, immagine 1 di 1
    • Pull the battery cable directly up from the logic board.
    • Remove the battery from its holder by pulling up and to the left.
  9. PowerBook G3 Pismo Modem Replacement: passo 9, immagine 1 di 1
  10. PowerBook G3 Pismo Modem Replacement, Heat Sink: passo 10, immagine 1 di 1
    • Remove the long silver Phillips #1 screw from the heat sink.
    • Remove the two T8 Torx screws that attach the heat sink to the processor.
  11. PowerBook G3 Pismo Modem Replacement: passo 11, immagine 1 di 1
    • Lift the heat sink up from the left side and pull it out.
    • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
  12. PowerBook G3 Pismo Modem Replacement, Processor: passo 12, immagine 1 di 1
    • Grasp the plastic tab on the processor's right side and pull it directly up.
    • Some processors may be missing the plastic pull tab. In this case, we suggest using a non-metal tool to gently pry up the processor. Slip the tool's thin edge under the front right corner of the processor and carefully pry it up.
  13. PowerBook G3 Pismo Modem Replacement: passo 13, immagine 1 di 1
  14. PowerBook G3 Pismo Modem Replacement, Modem: passo 14, immagine 1 di 1
    • Remove the black Torx screw from the right side of the modem.
    • Remove the small black plastic rectangle with four holes.
  15. PowerBook G3 Pismo Modem Replacement: passo 15, immagine 1 di 1
    • Use the tips of your fingers, a spudger, or a flat non-metal tool to get under the modem's edge and pry it up from its socket.
  16. PowerBook G3 Pismo Modem Replacement: passo 16, immagine 1 di 1
    • Disconnect the cable from the right side of the modem.
Conclusione
Documenti Allegati
iRobot
Membro da: 09/24/09
1 Reputazione
636 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 29
Tutti i Tempi: 3,837
