Salta al contenuto principale
PowerA Spectra Contoller D-Pad Replacement
Cosa ti serve
  1. PowerA Spectra Contoller D-Pad Replacement, Rear Case: passo 1, immagine 1 di 1
    • Flip the controller over so the backplate is facing up.
  2. PowerA Spectra Contoller D-Pad Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #2 screwdriver to remove the eight 7.8 mm screws that secure the rear case.
  3. PowerA Spectra Contoller D-Pad Replacement: passo 3, immagine 1 di 1
    • Hold the front case in one hand and pull the rear case off.
  4. PowerA Spectra Contoller D-Pad Replacement, D-Pad: passo 4, immagine 1 di 1
    • Use a Phillips screwdriver to remove the two 7.8 mm screws securing the motherboard to the chassis.
  5. PowerA Spectra Contoller D-Pad Replacement: passo 5, immagine 1 di 1
    • Gently take the motherboard off of the front plate.
  6. PowerA Spectra Contoller D-Pad Replacement: passo 6, immagine 1 di 1
    • Use Phillips screwdriver to remove the four 7.8 mm screws that secure the D-pad.
  7. PowerA Spectra Contoller D-Pad Replacement: passo 7, immagine 1 di 1
    • Gently pry off the D-pad.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 122
