Cosa ti serve
Press the green release button on top of the side access panel.
Pull off the side access panel to get inside the computer.
Lay the computer on its side, ensuring that where the side access panel was is facing up.
Passo 4 PCI Card(s)
Attenzione: il passaggio 4 proviene da una guida contrassegnata come in corso.
Unscrew the Phillips screw holding the PCI card in place.
Remove it.
Repeat this step for other PCI cards.
Remove the screw at the back of the computer holding the I/O card in place.
Using a Phillips screwdriver, unscrew the screw on the logic board holding the processor module wire in place.
Disconnect any and all cables connected to the logic board.
Remove the screw near the RAM securing the logic board in place.
