Salta al contenuto principale
Power Macintosh G3 Minitower PCI Card Replacement
Cosa ti serve
    • Press the green release button on top of the side access panel.
    • Pull off the side access panel to get inside the computer.
    • When putting the side access panel back on, make sure that the bottom of the panel lines up with the rail on the bottom, and that the chassis is locked with the green latches.
    • Lay the computer on its side, ensuring that where the side access panel was is facing up.
    • Unlock the top chassis by moving the two green locking latches upward and outward.
    • Using the handle, gently swing the top chassis up and out until it rests firmly on the work surface.
    • Unscrew the Phillips screw holding the PCI card in place.
    • Remove it.
    • Repeat this step for other PCI cards.
    • If you remove all the PCI cards and/or port access covers, make sure the sheet metal shield remains underneath the edge of the logic board.
Conclusione
LeoI07
Membro da: 06/10/21
1.573 Reputazione
17 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 12
