Salta al contenuto principale
Polaroid PTAB7XC Motherboard Replacement
Cosa ti serve
  1. Polaroid PTAB7XC Motherboard Replacement, Motherboard: passo 1, immagine 1 di 2 Polaroid PTAB7XC Motherboard Replacement, Motherboard: passo 1, immagine 2 di 2
    • Remove the two 7 mm screws on the top of the device using a J00 Phillips screwdriver to turn them counterclockwise.
    • If the screw heads have corroded or been stripped, it may be necessary to use a larger screwdriver head, such as the J0.
  2. Polaroid PTAB7XC Motherboard Replacement: passo 2, immagine 1 di 3 Polaroid PTAB7XC Motherboard Replacement: passo 2, immagine 2 di 3 Polaroid PTAB7XC Motherboard Replacement: passo 2, immagine 3 di 3
    • Pry the seam between the screen and the case on all four sides with a large plastic opening tool until the plastic case comes off.
    • Lift the device off of the case and flip over the device so that it sits screen side down.
    • The device is now free from the plastic casing.
    • The power and/or volume buttons may fall out at this point. There is no problem with this; however, be sure to remember to reinstall them when reassembling the device.
  3. Polaroid PTAB7XC Motherboard Replacement: passo 3, immagine 1 di 3 Polaroid PTAB7XC Motherboard Replacement: passo 3, immagine 2 di 3 Polaroid PTAB7XC Motherboard Replacement: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Set the device on a heat safe surface.
    • Desolder from the motherboard the red wire that connects to the battery unit.
    • Desolder from the motherboard the black wire that connects to the battery unit.
    • If either of the wires do not come completely free when desoldering, use tweezers to gently pull them free.
  4. Polaroid PTAB7XC Motherboard Replacement: passo 4, immagine 1 di 3 Polaroid PTAB7XC Motherboard Replacement: passo 4, immagine 2 di 3 Polaroid PTAB7XC Motherboard Replacement: passo 4, immagine 3 di 3
    • Desolder the following components from the motherboard.
    • Desolder from the motherboard the red wire that connects to the speaker unit.
    • Desolder from the motherboard the black wire that connects to the speaker unit.
    • Desolder from the motherboard the gray wire that runs along the edge of the device.
    • The motherboard will now be detached from any wires connecting to the device.
    • If any of the wires do not detach completely during the desoldering process, then gently pull them off using tweezers.
  5. Polaroid PTAB7XC Motherboard Replacement: passo 5, immagine 1 di 3 Polaroid PTAB7XC Motherboard Replacement: passo 5, immagine 2 di 3 Polaroid PTAB7XC Motherboard Replacement: passo 5, immagine 3 di 3
    • Use tweezers to unstick the medium width yellow ribbon cable from the motherboard
    • Use a small plastic opening tool to slide the two small black holding clips off of the white connector to which the medium width yellow ribbon cable is attached.
    • Use your fingers to gently pull the medium width yellow ribbon cable out of the white connector.
    • Repeat the last two actions to disconnect the narrower yellow ribbon cable and the wider yellow ribbon cable from the motherboard.
    • The motherboard will now be detached from any ribbon cables connecting to the device.
  6. Polaroid PTAB7XC Motherboard Replacement: passo 6, immagine 1 di 3 Polaroid PTAB7XC Motherboard Replacement: passo 6, immagine 2 di 3 Polaroid PTAB7XC Motherboard Replacement: passo 6, immagine 3 di 3
    • Use the PH000 screwdriver remove the four 5 mm screws along the bottom edge of the motherboard, turning them counterclockwise.
  7. Polaroid PTAB7XC Motherboard Replacement: passo 7, immagine 1 di 1
    • Using your index finger and thumb, lift the motherboard out of the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 435
