Introduzione
This process requires soldering and lots of smelly adhesive. For more information about soldering, take a look at this guide. Be careful, as a ruptured battery can be dangerous.
Strumenti
Parti
Nessuna parte specificata.
Remove the two 7 mm screws on the top of the device using a J00 Phillips screwdriver, turning them counterclockwise.
Set the device on a heat safe surface.
Desolder from the motherboard the red wire that connects to the battery unit.
Desolder from the motherboard the black wire that connects to the battery unit.
Lift the battery out of the device using your hands.
The battery is now free from the device.
Altre 4 persone hanno completato questa guida.
Un commento
This tablet has the exact same setup as the 2011-2012 nextbook part might be interchangeable with this tablet .
