Salta al contenuto principale
Polaroid A10 Speakers Replacement
Cosa ti serve
  1. Polaroid A10 Speakers Replacement, Back Cover: passo 1, immagine 1 di 3 Polaroid A10 Speakers Replacement, Back Cover: passo 1, immagine 2 di 3 Polaroid A10 Speakers Replacement, Back Cover: passo 1, immagine 3 di 3
    • Begin by having the side with volume and power button face up towards you.
    • Insert a plastic opening tool between the display and the back cover.
    • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
    • It is easier to remove the back cover, if the display screen is faced down.
    • The tabs must be released from all four sides before removing the back cover.
  2. Polaroid A10 Speakers Replacement, Speakers: passo 2, immagine 1 di 1
    • The speakers are located on the bottom of the device, below the battery and adjacent to the motherboard.
  3. Polaroid A10 Speakers Replacement: passo 3, immagine 1 di 3 Polaroid A10 Speakers Replacement: passo 3, immagine 2 di 3 Polaroid A10 Speakers Replacement: passo 3, immagine 3 di 3
    • Using the Phillips #000 screwdriver, remove the two 7 mm screws located in the picture by rotating the screw counter-clockwise.
    • Carefully remove the speakers from original position without pulling out the wires.
  4. Polaroid A10 Speakers Replacement: passo 4, immagine 1 di 1
    • Using the soldering tool, remove the two small black wires and two small red wires from the motherboard.
    • The wire connections are located on the motherboard next to the corner of the battery closest to the motherboard.
    • Removal and installation of wires requires soldering. Here's a helpful link to assist you with great soldering techniques.
  5. Polaroid A10 Speakers Replacement: passo 5, immagine 1 di 1
    • Gently lift the speakers up and out of the device.
Conclusione
Koby
Membro da: 01/22/15
104 Reputazione
1 Guida realizzata
UW Tacoma, Team 3-3, Rose Winter 2015 Membro di UW Tacoma, Team 3-3, Rose Winter 2015
UWT-ROSE-W15S3G3
4 Membri
12 Guide realizzate
3 Commenti
This is not what I meant I wanted to know what to do if the wires came out of the
amirahoresanwo - Replica
If the wires and out of the
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 255
