Salta al contenuto principale
Polaroid A10 Motherboard Replacement
Cosa ti serve
  1. Polaroid A10 Motherboard Replacement, Back Cover: passo 1, immagine 1 di 3 Polaroid A10 Motherboard Replacement, Back Cover: passo 1, immagine 2 di 3 Polaroid A10 Motherboard Replacement, Back Cover: passo 1, immagine 3 di 3
    • Begin by having the side with volume and power button face up towards you.
    • Insert a plastic opening tool between the display and the back cover.
    • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
    • It is easier to remove the back cover, if the display screen is faced down.
    • The tabs must be released from all four sides before removing the back cover.
  2. Polaroid A10 Motherboard Replacement, Motherboard: passo 2, immagine 1 di 3 Polaroid A10 Motherboard Replacement, Motherboard: passo 2, immagine 2 di 3 Polaroid A10 Motherboard Replacement, Motherboard: passo 2, immagine 3 di 3
    • Take off yellow tapes that are surrounding the motherboard.
    • Use the plastic opening tools to disconnect the three ribbon cables: battery, screen, and volume/power buttons.
  3. Polaroid A10 Motherboard Replacement: passo 3, immagine 1 di 3 Polaroid A10 Motherboard Replacement: passo 3, immagine 2 di 3 Polaroid A10 Motherboard Replacement: passo 3, immagine 3 di 3
    • Using the Phillips #000 screwdriver, remove the four 5 mm screws located in the picture by rotating the screw counter-clockwise.
  4. Polaroid A10 Motherboard Replacement: passo 4, immagine 1 di 2 Polaroid A10 Motherboard Replacement: passo 4, immagine 2 di 2
    • Use the soldering tool to unsolder the two bigger metals from the wires of the battery.
    • Use the same soldering tool to unsolder the four smaller metals from the wires of the speakers.
    • Use the same soldering tool to unsolder the ground wire.
    • Removal and installation of wires requires soldering. Here's a helpful link to assist you with great soldering techniques.
  5. Polaroid A10 Motherboard Replacement: passo 5, immagine 1 di 3 Polaroid A10 Motherboard Replacement: passo 5, immagine 2 di 3 Polaroid A10 Motherboard Replacement: passo 5, immagine 3 di 3
    • Gently lift the motherboard up and out of the device.
Conclusione
Tracie
Membro da: 01/22/15
119 Reputazione
1 Guida realizzata
UW Tacoma, Team 3-3, Rose Winter 2015 Membro di UW Tacoma, Team 3-3, Rose Winter 2015
UWT-ROSE-W15S3G3
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 611
