Salta al contenuto principale
Polaroid A10 Battery Replacement
Cosa ti serve
  1. Polaroid A10 Battery Replacement, Back Cover: passo 1, immagine 1 di 3 Polaroid A10 Battery Replacement, Back Cover: passo 1, immagine 2 di 3 Polaroid A10 Battery Replacement, Back Cover: passo 1, immagine 3 di 3
    • Begin by having the side with volume and power button face up towards you.
    • Insert a plastic opening tool between the display and the back cover.
    • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
    • It is easier to remove the back cover, if the display screen is faced down.
    • The tabs must be released from all four sides before removing the back cover.
  2. Polaroid A10 Battery Replacement, Battery: passo 2, immagine 1 di 3 Polaroid A10 Battery Replacement, Battery: passo 2, immagine 2 di 3 Polaroid A10 Battery Replacement, Battery: passo 2, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    Compra
    • Begin by inserting the flat end of a spudger underneath the battery to separate the glue from the battery.
    • It is better to use a plastic card if you have one.
    • Gently lift up the battery as you continue to separate the glue from the battery.
    • Lift up just enough to see where the glue is, so that you don't bend the battery.
    • Once the glue has been separated, gently lift up the battery and you will notice two wires attached to the motherboard.
  3. Polaroid A10 Battery Replacement: passo 3, immagine 1 di 3 Polaroid A10 Battery Replacement: passo 3, immagine 2 di 3 Polaroid A10 Battery Replacement: passo 3, immagine 3 di 3
  4. Polaroid A10 Battery Replacement: passo 4, immagine 1 di 1
    • Gently lift the battery up and out of the device.
Conclusione
armando
Membro da: 01/14/15
150 Reputazione
1 Guida realizzata
UW Tacoma, Team 3-3, Rose Winter 2015 Membro di UW Tacoma, Team 3-3, Rose Winter 2015
UWT-ROSE-W15S3G3
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 752
