Salta al contenuto principale
PlayStation Start and Select Buttons Replacement
Cosa ti serve
  1. PlayStation Start and Select Buttons Replacement, Start and Select Buttons: passo 1, immagine 1 di 1
    • Before you begin, unplug your controller and console to avoid accidentally turning it on during disassembly.
  2. PlayStation Start and Select Buttons Replacement: passo 2, immagine 1 di 3 PlayStation Start and Select Buttons Replacement: passo 2, immagine 2 di 3 PlayStation Start and Select Buttons Replacement: passo 2, immagine 3 di 3
    • Use a Phillips #1 screwdriver to remove the five 7.2 mm screws securing the rear cover.
  3. PlayStation Start and Select Buttons Replacement: passo 3, immagine 1 di 3 PlayStation Start and Select Buttons Replacement: passo 3, immagine 2 di 3 PlayStation Start and Select Buttons Replacement: passo 3, immagine 3 di 3
    • Gently push the rear cover towards the front of the #2 trigger buttons.
    • Lift the rear cover.
    • The #2 trigger buttons may come off when removing the cover.
  4. PlayStation Start and Select Buttons Replacement: passo 4, immagine 1 di 2 PlayStation Start and Select Buttons Replacement: passo 4, immagine 2 di 2
    • Lift the battery and set it beside the controller, with care not to strain the wires.
    • Use a Phillips #1 screwdriver to remove the single 7.2 mm screw securing the motherboard.
  5. PlayStation Start and Select Buttons Replacement: passo 5, immagine 1 di 2 PlayStation Start and Select Buttons Replacement: passo 5, immagine 2 di 2
    • Unclip the vibrating motors.
    • Be careful not to break the black and red wires connected to the motherboard. They are very fragile!
  6. PlayStation Start and Select Buttons Replacement: passo 6, immagine 1 di 2 PlayStation Start and Select Buttons Replacement: passo 6, immagine 2 di 2
    • Lift off the plastic housing holding the motherboard, battery, and vibrating motors.
  7. PlayStation Start and Select Buttons Replacement: passo 7, immagine 1 di 3 PlayStation Start and Select Buttons Replacement: passo 7, immagine 2 di 3 PlayStation Start and Select Buttons Replacement: passo 7, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the rubber buttons with a pair of tweezers.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 57
Tutti i Tempi: 1,707
