Salta al contenuto principale
PlayStation Portal L1 and R1 Bumpers Replacement
Cosa ti serve
  1. PlayStation Portal L1 and R1 Bumpers Replacement, Power off your PlayStation Portal: passo 1, immagine 1 di 2 PlayStation Portal L1 and R1 Bumpers Replacement, Power off your PlayStation Portal: passo 1, immagine 2 di 2
    • Before you begin repairs, power off your PlayStation Portal and unplug any cables.
  2. PlayStation Portal L1 and R1 Bumpers Replacement, Pry up the L1 bumper: passo 2, immagine 1 di 3 PlayStation Portal L1 and R1 Bumpers Replacement, Pry up the L1 bumper: passo 2, immagine 2 di 3 PlayStation Portal L1 and R1 Bumpers Replacement, Pry up the L1 bumper: passo 2, immagine 3 di 3
    • Both bumpers are held in place with clips.
    • Rest a finger over the L1 bumper to prevent it from flying off when you pry.
    • Insert the flat end of a spudger between the top edge of the bumper and the white shell.
    • Pry up to unclip the bumper.
    • Slide the spudger along the seam to release any remaining clips.
  3. PlayStation Portal L1 and R1 Bumpers Replacement: passo 3, immagine 1 di 1
    • Remove the L1 bumper.
  4. PlayStation Portal L1 and R1 Bumpers Replacement, Pry up the R1 bumper: passo 4, immagine 1 di 3 PlayStation Portal L1 and R1 Bumpers Replacement, Pry up the R1 bumper: passo 4, immagine 2 di 3 PlayStation Portal L1 and R1 Bumpers Replacement, Pry up the R1 bumper: passo 4, immagine 3 di 3
    • Repeat the procedure to pry up and remove the R1 bumper.
  5. PlayStation Portal L1 and R1 Bumpers Replacement, Reassembly information: passo 5, immagine 1 di 3 PlayStation Portal L1 and R1 Bumpers Replacement, Reassembly information: passo 5, immagine 2 di 3 PlayStation Portal L1 and R1 Bumpers Replacement, Reassembly information: passo 5, immagine 3 di 3
    • To install a bumper during reassembly:
    • Align the bumper into its slot.
    • Use a finger to press the bumper down firmly until it clicks into place.
Conclusione
Arthur Shi
Membro da: 01/03/18
283.398 Reputazione
587 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
19.648 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 88
Tutti i Tempi: 441
