Salta al contenuto principale
PlayStation Portal D-pad Replacement
Cosa ti serve
  1. PlayStation Portal D-pad Replacement, Power off your PlayStation Portal: passo 1, immagine 1 di 2 PlayStation Portal D-pad Replacement, Power off your PlayStation Portal: passo 1, immagine 2 di 2
    • Before you begin repairs, power off your PlayStation Portal and unplug any cables.
  2. PlayStation Portal D-pad Replacement, Pry up the L1 bumper: passo 2, immagine 1 di 3 PlayStation Portal D-pad Replacement, Pry up the L1 bumper: passo 2, immagine 2 di 3 PlayStation Portal D-pad Replacement, Pry up the L1 bumper: passo 2, immagine 3 di 3
    • Both bumpers are held in place with clips.
    • Rest a finger over the L1 bumper to prevent it from flying off when you pry.
    • Insert the flat end of a spudger between the top edge of the bumper and the white shell.
    • Pry up to unclip the bumper.
    • Slide the spudger along the seam to release any remaining clips.
  3. PlayStation Portal D-pad Replacement: passo 3, immagine 1 di 1
    • Remove the L1 bumper.
  4. PlayStation Portal D-pad Replacement, Pry up the R1 bumper: passo 4, immagine 1 di 3 PlayStation Portal D-pad Replacement, Pry up the R1 bumper: passo 4, immagine 2 di 3 PlayStation Portal D-pad Replacement, Pry up the R1 bumper: passo 4, immagine 3 di 3
    • Repeat the procedure to pry up and remove the R1 bumper.
  5. PlayStation Portal D-pad Replacement, Reassembly information: passo 5, immagine 1 di 3 PlayStation Portal D-pad Replacement, Reassembly information: passo 5, immagine 2 di 3 PlayStation Portal D-pad Replacement, Reassembly information: passo 5, immagine 3 di 3
    • To install a bumper during reassembly:
    • Align the bumper into its slot.
    • Use a finger to press the bumper down firmly until it clicks into place.
  6. PlayStation Portal D-pad Replacement, Loosen the left joystick trim strip: passo 6, immagine 1 di 2 PlayStation Portal D-pad Replacement, Loosen the left joystick trim strip: passo 6, immagine 2 di 2
    • Insert the tip of an opening pick underneath the left joystick trim strip, where it wraps below the grip.
    • Twist the opening pick to release the bottom clip.
  7. PlayStation Portal D-pad Replacement: passo 7, immagine 1 di 3 PlayStation Portal D-pad Replacement: passo 7, immagine 2 di 3 PlayStation Portal D-pad Replacement: passo 7, immagine 3 di 3
    • Insert the tip of an opening pick underneath the outer edge of the trim strip.
    • Slide the opening pick along the edge to release the clips.
  8. PlayStation Portal D-pad Replacement: passo 8, immagine 1 di 2 PlayStation Portal D-pad Replacement: passo 8, immagine 2 di 2
    • Insert the tip of an opening pick under the inner edge of the strip.
  9. PlayStation Portal D-pad Replacement: passo 9, immagine 1 di 2 PlayStation Portal D-pad Replacement: passo 9, immagine 2 di 2
    • Grasp the bottom edge of the trim strip and slowly lift to release any remaining clips.
    • If the strip feels stuck, twist or shift the strip sideways to help release any stubborn clips.
  10. PlayStation Portal D-pad Replacement, Remove the left joystick trim strip: passo 10, immagine 1 di 2 PlayStation Portal D-pad Replacement, Remove the left joystick trim strip: passo 10, immagine 2 di 2
    • Lift and remove the left joystick trim strip.
  11. PlayStation Portal D-pad Replacement, Remove the right joystick trim strip: passo 11, immagine 1 di 3 PlayStation Portal D-pad Replacement, Remove the right joystick trim strip: passo 11, immagine 2 di 3 PlayStation Portal D-pad Replacement, Remove the right joystick trim strip: passo 11, immagine 3 di 3
    • Repeat the procedure to unclip and remove the right joystick trim strip.
  12. PlayStation Portal D-pad Replacement, Reassembly information: passo 12, immagine 1 di 2 PlayStation Portal D-pad Replacement, Reassembly information: passo 12, immagine 2 di 2
    • To reattach a trim strip during reassembly:
    • Use your fingers to align and clip the top edge in place.
    • Firmly press along the remaining edges to clip the strip in place.
  13. PlayStation Portal D-pad Replacement, Remove the back shell screws: passo 13, immagine 1 di 2 PlayStation Portal D-pad Replacement, Remove the back shell screws: passo 13, immagine 2 di 2
    • Use a Phillips screwdriver to remove the two 6.5 mm‑long screws at the bottom tips of each grip.
    • You may need to peel off some tamper-evident stickers to access the screws.
  14. PlayStation Portal D-pad Replacement: passo 14, immagine 1 di 2 PlayStation Portal D-pad Replacement: passo 14, immagine 2 di 2
    • Use a Phillips screwdriver to remove the two 6.5 mm‑long screws securing the top corners of the shell.
  15. PlayStation Portal D-pad Replacement, Back shell information: passo 15, immagine 1 di 1
    • The back shell is still secured with numerous clips. The next few steps will show how to unclip the shell while reducing the chance of damaging the clips.
  16. PlayStation Portal D-pad Replacement, Unclip the back shell: passo 16, immagine 1 di 2 PlayStation Portal D-pad Replacement, Unclip the back shell: passo 16, immagine 2 di 2
    • Push the flat edge of a spudger into the back shell's left, inner seam.
    • This releases the clip in that area while flexing the shell slightly, creating a larger outer seam.
    • Keep the spudger inserted in the seam.
  17. PlayStation Portal D-pad Replacement: passo 17, immagine 1 di 3 PlayStation Portal D-pad Replacement: passo 17, immagine 2 di 3 PlayStation Portal D-pad Replacement: passo 17, immagine 3 di 3
    • Insert the tip of an opening pick into the shell's left, outer seam.
    • Slide the pick along the seam to release the clips securing the edge.
    • Keep a pick in the seam to prevent the shell from clipping back together.
  18. PlayStation Portal D-pad Replacement: passo 18, immagine 1 di 2 PlayStation Portal D-pad Replacement: passo 18, immagine 2 di 2
    • Remove the spudger from the inner seam.
  19. PlayStation Portal D-pad Replacement: passo 19, immagine 1 di 3 PlayStation Portal D-pad Replacement: passo 19, immagine 2 di 3 PlayStation Portal D-pad Replacement: passo 19, immagine 3 di 3
    • Repeat the previous three steps on the right side of the Portal to release the clips along the right edge.
  20. PlayStation Portal D-pad Replacement: passo 20, immagine 1 di 2 PlayStation Portal D-pad Replacement: passo 20, immagine 2 di 2
    • Carefully flip your Portal over.
    • Grasp the top edge of the back shell, near a corner.
    • Gently pull the top edge away until you feel the clips release in that corner.
  21. PlayStation Portal D-pad Replacement: passo 21, immagine 1 di 2 PlayStation Portal D-pad Replacement: passo 21, immagine 2 di 2
    • Pull along the top edge to release all the top edge clips.
  22. PlayStation Portal D-pad Replacement: passo 22, immagine 1 di 2 PlayStation Portal D-pad Replacement: passo 22, immagine 2 di 2
    • Grasp the bottom edge of the back shell, near the center.
    • Pull away with firm force to release the clips securing the bottom edge.
  23. PlayStation Portal D-pad Replacement, Remove the back shell: passo 23, immagine 1 di 2 PlayStation Portal D-pad Replacement, Remove the back shell: passo 23, immagine 2 di 2
    • Remove the back shell.
  24. PlayStation Portal D-pad Replacement, Reassembly information: passo 24, immagine 1 di 3 PlayStation Portal D-pad Replacement, Reassembly information: passo 24, immagine 2 di 3 PlayStation Portal D-pad Replacement, Reassembly information: passo 24, immagine 3 di 3
    • To clip the back shell in place during reassembly:
    • Align the corners near the trigger buttons first.
    • Firmly press around the entire perimeter to clip the shell back in place.
  25. PlayStation Portal D-pad Replacement, Loosen the left grip shell: passo 25, immagine 1 di 2 PlayStation Portal D-pad Replacement, Loosen the left grip shell: passo 25, immagine 2 di 2
    • Use a Phillips screwdriver to remove the two 6.5 mm‑long screws securing the left grip shell to the Portal.
    • From the back, these screws are on the right side of the Portal.
    • These screws can be tight. Brace the Portal with your hand and apply strong pressure to the screwdriver.
    • You can also try using a JIS #00 screwdriver to get a better grip on these screws.
  26. PlayStation Portal D-pad Replacement: passo 26, immagine 1 di 2 PlayStation Portal D-pad Replacement: passo 26, immagine 2 di 2
    • Grasp the top edge of the grip shell and twist it slightly outwards (away from the screen) to release the inner clips.
  27. PlayStation Portal D-pad Replacement, Remove the left grip shell: passo 27, immagine 1 di 3 PlayStation Portal D-pad Replacement, Remove the left grip shell: passo 27, immagine 2 di 3 PlayStation Portal D-pad Replacement, Remove the left grip shell: passo 27, immagine 3 di 3
    • Insert the flat edge of a spudger underneath the inner edge of the grip shell, near the vibration motor.
    • Twist the spudger along the edge to unclip the bottom portion of the grip shell.
    • Remove the left grip shell.
  28. PlayStation Portal D-pad Replacement, Remove the button cover: passo 28, immagine 1 di 3 PlayStation Portal D-pad Replacement, Remove the button cover: passo 28, immagine 2 di 3 PlayStation Portal D-pad Replacement, Remove the button cover: passo 28, immagine 3 di 3
    • Use your fingers to peel the gray button cover away from the grip shell and remove it.
    • During reassembly:
    • Make sure the orientation arrow on the button cover points upwards.
  29. PlayStation Portal D-pad Replacement, Remove the D-pad: passo 29, immagine 1 di 2 PlayStation Portal D-pad Replacement, Remove the D-pad: passo 29, immagine 2 di 2
    • Flip the grip shell over to drop out the D-pad.
    • Orient the D-pad such that the alignment tabs rest in the shell's cutouts.
Conclusione
Arthur Shi
Membro da: 01/03/18
283.229 Reputazione
587 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
19.583 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 47
Tutti i Tempi: 464
