Introduzione
Use this guide to replace your headset's motherboard
Cosa ti serve
Flip the headset face down.
Squeeze both sides of the battery cover.
While squeezing, pull the cover up slowly to remove it.
Use a hairdryer or heat gun to melt the adhesive along the crevice that joins the black and silver components.
Apply additional heat at the tip of the microphone.
Using a blow dryer or a heat gun, heat the crevice to melt the adhesive between the plastic covers.
Using a plastic opening tool, prop open the edges.
Gently pull the black speaker casing up to remove it.
