Salta al contenuto principale
Photive Rain Battery Replacement
Cosa ti serve
  1. Photive Rain Battery Replacement, Back Panel: passo 1, immagine 1 di 1
    • Turn the speaker off before disassembling.
    • Remove the suction cup from its groove by twisting and turning it.
  2. Photive Rain Battery Replacement: passo 2, immagine 1 di 1
    • Remove the four 8.5 mm screws from the back panel of the speaker by using the Phillips #1 Screwdriver.
    • Remove back panel
  3. Photive Rain Battery Replacement, Battery: passo 3, immagine 1 di 2 Photive Rain Battery Replacement, Battery: passo 3, immagine 2 di 2
    • Remove the plastic cover in front of the battery slot.
    • Unscrew all the 8.5mm screws that hold the cover to the slot.
    • Separate the battery from the back panel as shown in photograph 3.
    • Caution: manipulation of the device while the battery is still connected to the motherboard may result in electric shock.
  4. Photive Rain Battery Replacement: passo 4, immagine 1 di 1
    • Remove the battery from the motherboard.
    • Use a soldering pen to remove the solder connecting the battery wires to the motherboard.
    • Click here to access the iFixit Soldering Guide. This will provide a safe and instructive manual on the usage of soldering pens.
Conclusione
Altre 2 persone hanno completato questa guida.
IUPUI, Team 1-4, Harley Spring 2016 Membro di IUPUI, Team 1-4, Harley Spring 2016
IUPUI-HARLEY-S16S1G4
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 511
