Salta al contenuto principale
Philips Sonicare DiamondClean Motor Replacement
Cosa ti serve
  1. Philips Sonicare DiamondClean Motor Replacement, Motor: passo 1, immagine 1 di 2 Philips Sonicare DiamondClean Motor Replacement, Motor: passo 1, immagine 2 di 2
    • Pull the toothbrush head off the toothbrush.
  2. Philips Sonicare DiamondClean Motor Replacement: passo 2, immagine 1 di 1
    • Use a spudger to pry the chrome cap from the base of the toothbrush.
  3. Philips Sonicare DiamondClean Motor Replacement: passo 3, immagine 1 di 2 Philips Sonicare DiamondClean Motor Replacement: passo 3, immagine 2 di 2
    • Place the toothbrush upside down on a solid object and firmly, but gently, push down on the toothbrush until the internal components and case separate.
    • Note that there are clips inside the case but they are hard to access and unneeded to separate the components.
  4. Philips Sonicare DiamondClean Motor Replacement: passo 4, immagine 1 di 2 Philips Sonicare DiamondClean Motor Replacement: passo 4, immagine 2 di 2
    • Remove the rubber covers from the circuit board and battery.
  5. Philips Sonicare DiamondClean Motor Replacement: passo 5, immagine 1 di 1
    • Using a soldering iron, remove the solder from the positions marked 1 and 2 on the circuit board.
    • Check out our How to Solder and Desolder Connections guide for help with soldering best practices!
  6. Philips Sonicare DiamondClean Motor Replacement: passo 6, immagine 1 di 1
    • Slide and separate the two components of the internals from each other.
  7. Philips Sonicare DiamondClean Motor Replacement: passo 7, immagine 1 di 1
    • Gently remove the spring and rubber component.
  8. Philips Sonicare DiamondClean Motor Replacement: passo 8, immagine 1 di 2 Philips Sonicare DiamondClean Motor Replacement: passo 8, immagine 2 di 2
    • Remove the two 4mm Phillips #00 screws on both sides of the upper component.
  9. Philips Sonicare DiamondClean Motor Replacement: passo 9, immagine 1 di 2 Philips Sonicare DiamondClean Motor Replacement: passo 9, immagine 2 di 2
    • Gently bend and position the brackets to remove the motor.
  10. Philips Sonicare DiamondClean Motor Replacement: passo 10, immagine 1 di 1
    • Remove the motor and replace.
Conclusione
2 Commenti
Do you have a part number for the motor?
Suraj Daryapurkar - Replica
Double check if the vibrating end on step 4 is screwed tight. On my unit, I though the motor had an issue, whereas it just was that a screw on the vibrating end that had gotten loose.
Marsya Kaustentein - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 153
Tutti i Tempi: 6,106
