Salta al contenuto principale
Philips Sonicare DiamondClean Circuit Board Replacement
Cosa ti serve
  1. Philips Sonicare DiamondClean Circuit Board Replacement, Circuit Board: passo 1, immagine 1 di 2 Philips Sonicare DiamondClean Circuit Board Replacement, Circuit Board: passo 1, immagine 2 di 2
    • Pull the brush head from the toothbrush.
  2. Philips Sonicare DiamondClean Circuit Board Replacement: passo 2, immagine 1 di 1
    • Use a spudger to pry the chrome cap from the base of the toothbrush.
  3. Philips Sonicare DiamondClean Circuit Board Replacement: passo 3, immagine 1 di 3 Philips Sonicare DiamondClean Circuit Board Replacement: passo 3, immagine 2 di 3 Philips Sonicare DiamondClean Circuit Board Replacement: passo 3, immagine 3 di 3
    • Invert the toothbrush and apply pressure against the metal tip until the internals and casing separate.
    • Remove the internals from the casing.
  4. Philips Sonicare DiamondClean Circuit Board Replacement: passo 4, immagine 1 di 1
    • Remove the rubber covers from the circuit board and battery.
  5. Philips Sonicare DiamondClean Circuit Board Replacement: passo 5, immagine 1 di 1
    • Carefully free the top end of the circuit board from the plastic clips holding it in place.
  6. Philips Sonicare DiamondClean Circuit Board Replacement: passo 6, immagine 1 di 1
    • Use the soldering iron to desolder the terminals marked F1, C5, R7, R6, and JP1.
    • Check out our How to Solder and Desolder Connections guide for help with soldering best practices!
    • Remove the circuit board.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 56
Tutti i Tempi: 2,810
