Salta al contenuto principale
Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement
Cosa ti serve
  1. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement, LED Board: passo 1, immagine 1 di 2 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement, LED Board: passo 1, immagine 2 di 2
    • Place thumb behind trimming blade and push up to open.
  2. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 2, immagine 1 di 3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 2, immagine 2 di 3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 2, immagine 3 di 3
    • Remove two screws (M2 x 9.5) on metal plate with JIS 0 screwdriver bit.
    • Use spudger to pry off metal plate.
    • Slide up plastic housing to remove the trimmer.
  3. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 3, immagine 1 di 3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 3, immagine 2 di 3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 3, immagine 3 di 3
    • Slide chrome outer plastic towards removed trimmer.
    • Flip to the other side and repeat, sliding the chrome plastic towards removed trimmer.
  4. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 4, immagine 1 di 2 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 4, immagine 2 di 2
    • Remove two top screws (M2 x 6.9) with the JIS 00 screwdriver bit.
    • Remove two bottom screws (M2 x 6.9) with the same bit.
  5. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 5, immagine 1 di 3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 5, immagine 2 di 3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 5, immagine 3 di 3
    • Use spudger to pry off top of the battery cover. WARNING: fairly difficult, be aware significant amount of force required.
    • Use spudger to remove bottom of the battery cover, and remove it.
  6. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 6, immagine 1 di 2 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 6, immagine 2 di 2
    • Use a nylon spudger to pry out battery pack and the attached LED board.
  7. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 7, immagine 1 di 3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 7, immagine 2 di 3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: passo 7, immagine 3 di 3
    • Unwrap electrical tape around the battery pack and LED board.
    • Desolder the LED board from the battery pack.
    • Solder the new LED board back to the connection to battery pack.
Conclusione
Altre 2 persone hanno completato questa guida.
August Post
Membro da: 11/07/17
415 Reputazione
3 Guide realizzate
IUPUI, Team S2-G4, Harley Fall 2017 Membro di IUPUI, Team S2-G4, Harley Fall 2017
IUPUI-HARLEY-F17S2G4
3 Membri
7 Guide realizzate
Un commento
Can you point me in the right direction for finding a replacement board? I’m having trouble finding one. Thanks.
Alex - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 21
Tutti i Tempi: 606
