Salta al contenuto principale
Philips Norelco 5801XL Battery Replacement
Cosa ti serve
  1. Philips Norelco 5801XL Battery Replacement, Battery: passo 1, immagine 1 di 2 Philips Norelco 5801XL Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Using a T8 torx screwdriver, remove both 2mm T8 screws.
  2. Philips Norelco 5801XL Battery Replacement: passo 2, immagine 1 di 2 Philips Norelco 5801XL Battery Replacement: passo 2, immagine 2 di 2
    • Using a plastic opening tool, separate the front housing from the back housing.
    • Carefully pull the housing apart.
  3. Philips Norelco 5801XL Battery Replacement: passo 3, immagine 1 di 3 Philips Norelco 5801XL Battery Replacement: passo 3, immagine 2 di 3 Philips Norelco 5801XL Battery Replacement: passo 3, immagine 3 di 3
    • Remove the plastic bracket using a plastic opening tool.
    • Pry from the inside of the bracket towards the outside of the housing to remove it.
  4. Philips Norelco 5801XL Battery Replacement: passo 4, immagine 1 di 1
    • Remove the two T8 2mm Philips screws holding onto the bracket over the charge port.
    • Remove the bracket. It will pull straight out.
  5. Philips Norelco 5801XL Battery Replacement: passo 5, immagine 1 di 1
    • Push in the charge port using the plastic opening tool.
  6. Philips Norelco 5801XL Battery Replacement: passo 6, immagine 1 di 1
    • Lift the circuit board upwards and fold it towards the head of the razor.
    • Do not break the contacts connecting the board to the motor.
  7. Philips Norelco 5801XL Battery Replacement: passo 7, immagine 1 di 3 Philips Norelco 5801XL Battery Replacement: passo 7, immagine 2 di 3 Philips Norelco 5801XL Battery Replacement: passo 7, immagine 3 di 3
    • Desolder the contacts where the battery connects to the circuit board.
    • Straighten the battery contacts and pull them through the opposite side of the circuit board.
Conclusione
Altre 3 persone hanno completato questa guida.
Ben Gibbs
Membro da: 02/16/16
361 Reputazione
3 Guide realizzate
IUPUI, Team 3-2, Harley Spring 2016 Membro di IUPUI, Team 3-2, Harley Spring 2016
IUPUI-HARLEY-S16S3G2
4 Membri
6 Guide realizzate
3 Commenti
The replacement battery I bought had contact strips that were too long and too wide for the slots on the circuit board, so I had to trim off about half the length and 1.5 mm of the width on each strip, but after that alteration, it worked fine.
Tom Hess - Replica
What size is the Rechargeable Battery in the Norelco 5801XL .
Dave - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 26
Tutti i Tempi: 4,372
