Salta al contenuto principale
Philips DC320 37 LCD Screen Replacement
Cosa ti serve
    1. Philips DC320 37 LCD Screen Replacement, Docking entertainment system: passo 1, immagine 1 di 1
      • Pry off the four white feet with the pointed end of the spudger
      Chiedi a FixBot
      Aggiungi Commento
    2. Philips DC320 37 LCD Screen Replacement: passo 2, immagine 1 di 1
      • Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
      Chiedi a FixBot
      Aggiungi Commento
    3. Philips DC320 37 LCD Screen Replacement: passo 3, immagine 1 di 1
      • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
      • The connectors on the panel are fragile and may break.
      Chiedi a FixBot
      Aggiungi Commento
    4. Philips DC320 37 LCD Screen Replacement: passo 4, immagine 1 di 3 Philips DC320 37 LCD Screen Replacement: passo 4, immagine 2 di 3 Philips DC320 37 LCD Screen Replacement: passo 4, immagine 3 di 3
      • Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
      • Electrical Connectors
      • Ribbon Connectors
      • The cables do not have a lot of slack in them. Be careful not to break the connectors.
      • One wire is soldered onto the bottom panel. Be careful not to break this bond.
      Chiedi a FixBot
      Aggiungi Commento
    1. Philips DC320 37 LCD Screen Replacement, Speaker: passo 5, immagine 1 di 1
      • Unscrew the two 6 mm Phillips #00 screws attaching the back panel to device.
      Chiedi a FixBot
      Aggiungi Commento
    2. Philips DC320 37 LCD Screen Replacement: passo 6, immagine 1 di 3 Philips DC320 37 LCD Screen Replacement: passo 6, immagine 2 di 3 Philips DC320 37 LCD Screen Replacement: passo 6, immagine 3 di 3
      • Slide the back panel towards top of the device and lift away from the device to detach back panel.
      Chiedi a FixBot
      Aggiungi Commento
    3. Philips DC320 37 LCD Screen Replacement: passo 7, immagine 1 di 1
      • Unscrew the four 16 mm Phillips #2 screws attaching the speaker unit to device.
      Chiedi a FixBot
      Aggiungi Commento
    4. Philips DC320 37 LCD Screen Replacement: passo 8, immagine 1 di 2 Philips DC320 37 LCD Screen Replacement: passo 8, immagine 2 di 2
      • Slide the speaker towards the bottom of the device to remove.
      Chiedi a FixBot
      Aggiungi Commento
    1. Philips DC320 37 LCD Screen Replacement, LCD Screen: passo 9, immagine 1 di 3 Philips DC320 37 LCD Screen Replacement, LCD Screen: passo 9, immagine 2 di 3 Philips DC320 37 LCD Screen Replacement, LCD Screen: passo 9, immagine 3 di 3
      • Unscrew the seven 6 mm Phillips #00 screws holding the grey side piece to the black front panel.
      • Five of the Phillips #00 screws are on the LCD board. The other two are on the dock's bottom circuit board.
      • Unscrew the two 8 mm Phillips #1 screws that go through the grey piece and the LCD motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    2. Philips DC320 37 LCD Screen Replacement: passo 10, immagine 1 di 1
      • Remove the ribbon cable from the ZIF connector by pulling out the two black tabs with the pointed end of the spudger then pulling the cable straight out of the connector.
      Chiedi a FixBot
      Aggiungi Commento
    3. Philips DC320 37 LCD Screen Replacement: passo 11, immagine 1 di 2 Philips DC320 37 LCD Screen Replacement: passo 11, immagine 2 di 2
      • Remove the grey side piece from the black front panel by pulling it straight up. It should easily slide off.
      Chiedi a FixBot
      Aggiungi Commento
    4. Philips DC320 37 LCD Screen Replacement: passo 12, immagine 1 di 2 Philips DC320 37 LCD Screen Replacement: passo 12, immagine 2 di 2
      • Unscrew the six 8 mm Phillips #1 screws holding the LCD screen to the black front panel.
      • Unscrew the two 6 mm Phillips #00 screws from the top of the panel holding the the LCD screen to the front panel.
      • Pull the LCD and circuit board off of the front panel.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Cal Poly, Team 3-48, Amido Spring 2013 Membro di Cal Poly, Team 3-48, Amido Spring 2013
CPSU-AMIDO-S13S3G48
4 Membri
19 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 25
Tutti i Tempi: 1,816
