Salta al contenuto principale
Pentax Spotmatic Light Meter Calibration
Cosa ti serve
  1. Pentax Spotmatic Light Meter Calibration, Open film door: passo 1, immagine 1 di 1
    • Open the flim door.
  2. Pentax Spotmatic Light Meter Calibration, Remove the rewind knob: passo 2, immagine 1 di 3 Pentax Spotmatic Light Meter Calibration, Remove the rewind knob: passo 2, immagine 2 di 3 Pentax Spotmatic Light Meter Calibration, Remove the rewind knob: passo 2, immagine 3 di 3
    • Place a thin, sturdy tool in the spindle fork.
    • Unscrew the rewind knob.
    • Use a spanner wrench to unscrew the retaining nut.
    • Remove the film reminder
    • Remove the spring washer.
    • Remove the friction plate.
    • Keep the film door open for the duration of the light meter adjustment. It can be difficult to open without the rewind knob installed.
    • Mount a lens on the camera.
    • Create a scene of known brightness in front of the camera.
    • Adjust the aperture, shutter speed and ISO to achieve proper exposure for the chosen scene.
    • Switch on the light meter.
  3. Pentax Spotmatic Light Meter Calibration, Make adjustments: passo 4, immagine 1 di 2 Pentax Spotmatic Light Meter Calibration, Make adjustments: passo 4, immagine 2 di 2
    • Use a pick to adjust the variable resistor through the opening in the top plate.
    • Turn it until the needle in the viewfinder is centered in the opening, indicating a proper exposure.
    • The adjustment resistor shown with the top cover removed.
    • Repeat steps 3 and 4 for several different light levels.
    • Since the Spotmatic only has one adjustment resistor, it may not be possible to center the needle at every light level. Make compromises as necessary.
Conclusione
Sam Gustafson
Membro da: 09/01/22
7.682 Reputazione
42 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 93
Tutti i Tempi: 275
