Introduzione
Use this guide to replace the buttons on the back of the camera that control the various menu options.
  1. Remove all four 1 mm JIS #00 screws from the back of the camera. Remove all four 1 mm JIS #00 screws from the back of the camera.
    • Remove all four 1 mm JIS #00 screws from the back of the camera.
  2. Use your finger to peel the grip off the top of the camera.
    • Use your finger to peel the grip off the top of the camera.
    • For best results, start from the right side of the camera, opposite the buttons.
    • Once the grip is removed, you will most likely lose the water-tight seal.
  3. Use the tweezers to remove the two buttons from the top of the camera.
    • Use the tweezers to remove the two buttons from the top of the camera.
    • The buttons may fall out while removing the grip.
  4. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  5. Remove the three 1 mm JIS #000 screws from the top. Remove the 1 mm JIS #000 screw from the bottom. Remove the 1 mm JIS #000 screw from the bottom.
    • Remove the three 1 mm JIS #000 screws from the top.
    • Remove the 1 mm JIS #000 screw from the bottom.
  6. Carefully separate the back and the front of the camera.
    • Carefully separate the back and the front of the camera.
    • There are three ribbon cables connecting the two boards. Be careful not to tear them.
  7. Use the tip of a spudger to flip up the small retaining flaps on the ribbon cable ZIF connectors.
    • Use the tip of a spudger to flip up the small retaining flaps on the ribbon cable ZIF connectors.
    • Carefully pull the ribbon cables out of their sockets.
  8. Remove the eight JS#000 screws using a screwdriver and lift panel up. This screw does not need to be removed.
    • Remove the eight JS#000 screws using a screwdriver and lift panel up.
    • This screw does not need to be removed.
  9. Once panel is removed the button 'sheet' can be removed.
    • Once panel is removed the button 'sheet' can be removed.
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 181
