Introduzione
Use this guide to remove and replace a damaged battery cover on the Pentax Optio WG-2.
Cosa ti serve
Passo 1 Back Case
Attenzione: i passaggi 1-6 provengono da una guida contrassegnata come in corso.
Remove all four 1 mm JIS #00 screws from the back of the camera.
Lift the cover as you normally would if replacing battery.
Holding the camera with the lens facing away from you and the battery slot upward slide the cover towards the back of the camera.
