Salta al contenuto principale
Parrot Skycontroller 2 Power Port Replacement
Cosa ti serve
  1. Parrot Skycontroller 2 Power Port  Replacement, Power Port: passo 1, immagine 1 di 3 Parrot Skycontroller 2 Power Port  Replacement, Power Port: passo 1, immagine 2 di 3 Parrot Skycontroller 2 Power Port  Replacement, Power Port: passo 1, immagine 3 di 3
    • Flip the controller upside down.
  2. Parrot Skycontroller 2 Power Port  Replacement: passo 2, immagine 1 di 1
    • Remove one 9mm screw using a #4 flathead screwdriver.
  3. Parrot Skycontroller 2 Power Port  Replacement: passo 3, immagine 1 di 3 Parrot Skycontroller 2 Power Port  Replacement: passo 3, immagine 2 di 3 Parrot Skycontroller 2 Power Port  Replacement: passo 3, immagine 3 di 3
    • Insert the plastic opening tool into the top of the battery cover and pry upwards to lift the cover.
    • Remove the cover by pulling up and out.
  4. Parrot Skycontroller 2 Power Port  Replacement: passo 4, immagine 1 di 3 Parrot Skycontroller 2 Power Port  Replacement: passo 4, immagine 2 di 3 Parrot Skycontroller 2 Power Port  Replacement: passo 4, immagine 3 di 3
    • Pull the connectors out by gently pushing the tabs and pulling up on the connector.
    • Disconnect the battery from the remote by pressing the white tab and pulling apart.
  5. Parrot Skycontroller 2 Power Port  Replacement: passo 5, immagine 1 di 2 Parrot Skycontroller 2 Power Port  Replacement: passo 5, immagine 2 di 2
    • Remove the battery from it's brackets by pulling up gently on the ends of the battery.
    • Some force may be required to separate the battery from it's brackets.
  6. Parrot Skycontroller 2 Power Port  Replacement: passo 6, immagine 1 di 1
    • Remove the seven black 11mm screws using the Torx TR6 screwdriver.
    • There is a hidden screw located behind the sticker in the battery compartment.
    • Pull back the sticker with your finger nail and remove the one black 11mm screw using the Torx TR6 screwdriver.
  7. Parrot Skycontroller 2 Power Port  Replacement: passo 7, immagine 1 di 3 Parrot Skycontroller 2 Power Port  Replacement: passo 7, immagine 2 di 3 Parrot Skycontroller 2 Power Port  Replacement: passo 7, immagine 3 di 3
    • Remove the seven silver 4mm screws from around the edge of the top panel using the Torx TR6 Screwdriver.
    • The opposite side to the third picture has a screw located on each side of the USB port.
  8. Parrot Skycontroller 2 Power Port  Replacement: passo 8, immagine 1 di 1
    • Remove the battery compartment plate by pulling up and out.
  9. Parrot Skycontroller 2 Power Port  Replacement: passo 9, immagine 1 di 1
    • Remove the top plate by pushing on the corners with your hand.
    • Be careful to not pull too hard on the cable.
  10. Parrot Skycontroller 2 Power Port  Replacement: passo 10, immagine 1 di 3 Parrot Skycontroller 2 Power Port  Replacement: passo 10, immagine 2 di 3 Parrot Skycontroller 2 Power Port  Replacement: passo 10, immagine 3 di 3
    • Remove the face plate by pulling up and out.
  11. Parrot Skycontroller 2 Power Port  Replacement: passo 11, immagine 1 di 3 Parrot Skycontroller 2 Power Port  Replacement: passo 11, immagine 2 di 3 Parrot Skycontroller 2 Power Port  Replacement: passo 11, immagine 3 di 3
    • Make sure the controller is flat, then proceed to desolder the power port.
    • Desolder the four connection points surrounding the charging port.
    • Remove the power port from the controller.
    • For help with soldering best practices, check out our How to Solder and Desolder Connections guide.
    • Excessive heat can damage the power port, so do not apply the soldering iron to the component for too long.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 629
