Salta al contenuto principale
Panasonic Lumix DMC-ZS60 Camera Sensor Replacement
Cosa ti serve
  1. Panasonic Lumix DMC-ZS60 Camera Sensor Replacement, Battery: passo 1, immagine 1 di 1
    • Use your finger to slide the black latch from the locked position to the open position on the memory card/battery door. This will open the door of the camera.
  2. Panasonic Lumix DMC-ZS60 Camera Sensor Replacement: passo 2, immagine 1 di 2 Panasonic Lumix DMC-ZS60 Camera Sensor Replacement: passo 2, immagine 2 di 2
    • Push up the black tab on the right-hand-side to spring release the battery.
  3. Panasonic Lumix DMC-ZS60 Camera Sensor Replacement: passo 3, immagine 1 di 1
    • Remove the battery by sliding it out from the camera.
  4. Panasonic Lumix DMC-ZS60 Camera Sensor Replacement, LCD Screen: passo 4, immagine 1 di 3 Panasonic Lumix DMC-ZS60 Camera Sensor Replacement, LCD Screen: passo 4, immagine 2 di 3 Panasonic Lumix DMC-ZS60 Camera Sensor Replacement, LCD Screen: passo 4, immagine 3 di 3
    • Using the Phillips #000 Screwdriver, unscrew six 3mm screws. There are two screws located on three sides excluding the top.
  5. Panasonic Lumix DMC-ZS60 Camera Sensor Replacement: passo 5, immagine 1 di 1
    • Pry off back casing and set aside.
  6. Panasonic Lumix DMC-ZS60 Camera Sensor Replacement: passo 6, immagine 1 di 2 Panasonic Lumix DMC-ZS60 Camera Sensor Replacement: passo 6, immagine 2 di 2
    • Pull the right side control dial circuit board up.
    • Use tweezers to pry up the white retaining flap and gently pull the circuit board out.
  7. Panasonic Lumix DMC-ZS60 Camera Sensor Replacement: passo 7, immagine 1 di 3 Panasonic Lumix DMC-ZS60 Camera Sensor Replacement: passo 7, immagine 2 di 3 Panasonic Lumix DMC-ZS60 Camera Sensor Replacement: passo 7, immagine 3 di 3
    • Flip the LCD screen to the left.
    • Unscrew the two 3mm on the top right side using the Phillips #000 Screwdriver.
    • Lift the gray plate cover off.
  8. Panasonic Lumix DMC-ZS60 Camera Sensor Replacement: passo 8, immagine 1 di 2 Panasonic Lumix DMC-ZS60 Camera Sensor Replacement: passo 8, immagine 2 di 2
    • Use tweezers to pry up the black retaining flat and gently pull to free the LCD screen from the device.
  9. Panasonic Lumix DMC-ZS60 Camera Sensor Replacement, Motherboard: passo 9, immagine 1 di 1
    • Remove these three 3 mm screws with a Phillips #000 screwdriver.
  10. Panasonic Lumix DMC-ZS60 Camera Sensor Replacement: passo 10, immagine 1 di 3 Panasonic Lumix DMC-ZS60 Camera Sensor Replacement: passo 10, immagine 2 di 3 Panasonic Lumix DMC-ZS60 Camera Sensor Replacement: passo 10, immagine 3 di 3
    • Disconnect these 9 ribbon cables from the motherboard. One ribbon cable is hidden underneath the larger one on the left.
    • Use tweezers to first lift up the retaining flaps for each connector, then pull out the ribbon cable.
  11. Panasonic Lumix DMC-ZS60 Camera Sensor Replacement: passo 11, immagine 1 di 2 Panasonic Lumix DMC-ZS60 Camera Sensor Replacement: passo 11, immagine 2 di 2
    • Now you will able to lift the motherboard up and it will only be connected by two cables.
    • To fully remove the motherboard, you will have to solder the metal in order to remove the wires.
    • For more information on soldering, please visit the How to Solder and Desolder Connections guide.
  12. Panasonic Lumix DMC-ZS60 Camera Sensor Replacement, Camera Lens: passo 12, immagine 1 di 2 Panasonic Lumix DMC-ZS60 Camera Sensor Replacement, Camera Lens: passo 12, immagine 2 di 2
    • Unscrew the three 3mm screws attached to the plate cover using a Phillips #000 Screwdriver.
    • Pull off the plate cover to uncover the camera lens.
  13. Panasonic Lumix DMC-ZS60 Camera Sensor Replacement: passo 13, immagine 1 di 2 Panasonic Lumix DMC-ZS60 Camera Sensor Replacement: passo 13, immagine 2 di 2
    • Lift the camera lens from the camera.
  14. Panasonic Lumix DMC-ZS60 Camera Sensor Replacement, Camera Sensor: passo 14, immagine 1 di 3 Panasonic Lumix DMC-ZS60 Camera Sensor Replacement, Camera Sensor: passo 14, immagine 2 di 3 Panasonic Lumix DMC-ZS60 Camera Sensor Replacement, Camera Sensor: passo 14, immagine 3 di 3
    • Unscrew three screws using the T2 Torx Screwdriver.
    • Remove the camera sensor.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 17
Tutti i Tempi: 643
