Salta al contenuto principale
Panasonic LUMIX DMC-LX100 Motherboard Replacement
Cosa ti serve
  1. Panasonic LUMIX DMC-LX100 Motherboard Replacement, Battery: passo 1, immagine 1 di 3 Panasonic LUMIX DMC-LX100 Motherboard Replacement, Battery: passo 1, immagine 2 di 3 Panasonic LUMIX DMC-LX100 Motherboard Replacement, Battery: passo 1, immagine 3 di 3
    • Looking at the bottom of the camera, slide the OPEN/LOCK switch to the left into the OPEN position.
    • The battery housing door should swing open.
  2. Panasonic LUMIX DMC-LX100 Motherboard Replacement: passo 2, immagine 1 di 2 Panasonic LUMIX DMC-LX100 Motherboard Replacement: passo 2, immagine 2 di 2
    • Flip the inside switch up to release the battery.
  3. Panasonic LUMIX DMC-LX100 Motherboard Replacement: passo 3, immagine 1 di 1
    • Grip the edge of the battery and pull it out.
    • Use a LUMIX Panasonic DMW-BLE9PP Battery Pack for replacement.
  4. Panasonic LUMIX DMC-LX100 Motherboard Replacement, LCD Screen: passo 4, immagine 1 di 3 Panasonic LUMIX DMC-LX100 Motherboard Replacement, LCD Screen: passo 4, immagine 2 di 3 Panasonic LUMIX DMC-LX100 Motherboard Replacement, LCD Screen: passo 4, immagine 3 di 3
    • Some of these screws may have adhesive to keep the camera from being taken apart so push hard with the screwdriver and turn slowly to avoid stripping screws.
    • Use a Phillips #000 screwdriver to remove the five 4.5 mm screws located on the bottom of the camera and the top one on the left side, with the lens facing you.
    • Use a Phillips #000 screwdriver to remove the two 3.5 mm screws, one below the lens and one on the left side.
    • Use a Phillips #000 screwdriver to remove the 7.1 mm screw from the right side of the camera.
  5. Panasonic LUMIX DMC-LX100 Motherboard Replacement: passo 5, immagine 1 di 1
    • The viewfinder in this picture is taken off of the camera to more easily see where the screw is located. It is not actually removed from the camera.
    • Use a Phillips #000 screwdriver to remove the 2.5 mm screw underneath the viewfinder.
    • Pull the black plastic piece off of the viewfinder.
  6. Panasonic LUMIX DMC-LX100 Motherboard Replacement: passo 6, immagine 1 di 3 Panasonic LUMIX DMC-LX100 Motherboard Replacement: passo 6, immagine 2 di 3 Panasonic LUMIX DMC-LX100 Motherboard Replacement: passo 6, immagine 3 di 3
    • Slide out the black plastic piece that acts as a placeholder for an attachable lens on the top of the camera.
    • Remove the small metal insert that rests beneath the black plastic piece by pulling outward, away from the lens side of the camera.
    • You may need a spudger or prying device to remove the metal piece by lifting the back end up.
  7. Panasonic LUMIX DMC-LX100 Motherboard Replacement: passo 7, immagine 1 di 1
    • Use a Phillips #000 screwdriver to remove all four of the 7.1mm screws that are under the metal piece.
  8. Panasonic LUMIX DMC-LX100 Motherboard Replacement: passo 8, immagine 1 di 1
    • There may be adhesive holding the back on, so pry carefully to not break any of the ribbon cables underneath.
    • Pry off the back of the camera using a spudger starting from the top right side of the LCD screen.
  9. Panasonic LUMIX DMC-LX100 Motherboard Replacement: passo 9, immagine 1 di 1
    • Use a Phillips #000 screwdriver to remove the 7.5mm screw on the top right of the back of the camera that holds the metal backing in place.
  10. Panasonic LUMIX DMC-LX100 Motherboard Replacement: passo 10, immagine 1 di 3 Panasonic LUMIX DMC-LX100 Motherboard Replacement: passo 10, immagine 2 di 3 Panasonic LUMIX DMC-LX100 Motherboard Replacement: passo 10, immagine 3 di 3
    • Lift the LCD screen away from the device.
    • Pry off the silver metal backing with a spudger.
    • Pull out the ribbon cable that attaches the LCD screen to the motherboard.
    • If need be, use a plastic spudger to pry the ribbon cable out of its socket.
    • Remove the LCD screen.
  11. Panasonic LUMIX DMC-LX100 Motherboard Replacement, Motherboard: passo 11, immagine 1 di 1
    • You may need to use tweezers and a spudger to disconnect some of the ribbon cables so they do not break.
    • Disconnect the nine visible ribbon cables/ZIF connectors by flipping the black bars up and pulling the ribbon straight out of the connector.
    • Disconnect two more cables in the upper left corner of the board, hidden behind the visible cables.
    • Learn more about disconnecting ZIF connectors here.
  12. Panasonic LUMIX DMC-LX100 Motherboard Replacement: passo 12, immagine 1 di 1
    • Use a Phillips #000 screwdriver to remove the two 4.5 mm screws.
    • Use a Phillips #000 screwdriver to remove the 2.5 mm screw.
  13. Panasonic LUMIX DMC-LX100 Motherboard Replacement: passo 13, immagine 1 di 2 Panasonic LUMIX DMC-LX100 Motherboard Replacement: passo 13, immagine 2 di 2
    • Use two fingers to gently pull the viewfinder toward you and out of its housing.
    • The black plastic piece is still on the viewfinder in this image, but should have been removed during LCD screen removal.
  14. Panasonic LUMIX DMC-LX100 Motherboard Replacement: passo 14, immagine 1 di 2 Panasonic LUMIX DMC-LX100 Motherboard Replacement: passo 14, immagine 2 di 2
    • Start at the top of the camera and use the plastic spudger to pry the motherboard out of the camera.
Conclusione
Altre 3 persone hanno completato questa guida.
Sydney Dye
Membro da: 01/11/16
1.206 Reputazione
2 Guide realizzate
Cal Poly, Team 70-4, Forte Winter 2016 Membro di Cal Poly, Team 70-4, Forte Winter 2016
CPSU-FORTE-W16S70G4
4 Membri
9 Guide realizzate
2 Commenti
This camera is a true dust harvester.
Thanks to this guide I have dared to clean the sensor successfully.
I know that I will have to return to the task in a few months but now I am more sure of the process.
Thanks a lot
guillem garces - Replica
Just a quick question! After replacing the motherboard, the camera works just fine or is it needed a software intervention?
Domenico Toscani - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 48
Tutti i Tempi: 4,931
