Salta al contenuto principale
Panasonic KX-TGA600M Speaker Replacement
Cosa ti serve
  1. Panasonic KX-TGA600M Speaker Replacement, Battery: passo 1, immagine 1 di 2 Panasonic KX-TGA600M Speaker Replacement, Battery: passo 1, immagine 2 di 2
    • On the back of the phone, remove battery cover.
    • Push down on the marked indentation and pull downwards.
  2. Panasonic KX-TGA600M Speaker Replacement: passo 2, immagine 1 di 1
    • Pull out to remove the battery.
  3. Panasonic KX-TGA600M Speaker Replacement, Speaker: passo 3, immagine 1 di 1
    • Unscrew the two screws on the bottom left and right.
  4. Panasonic KX-TGA600M Speaker Replacement: passo 4, immagine 1 di 2 Panasonic KX-TGA600M Speaker Replacement: passo 4, immagine 2 di 2
    • Separate the front and back of the phone.
    • Store loose pieces for later replacement.
  5. Panasonic KX-TGA600M Speaker Replacement: passo 5, immagine 1 di 1
    • Remove the speaker housing.
    • During reassembly, solder the wires onto the speaker housing. For information on soldering, please refer to iFixit's soldering technique guide.
Conclusione
Kaleb Barquera
Membro da: 01/31/17
101 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 12
Tutti i Tempi: 622
