Salta al contenuto principale
Palm m105 Display Screen Replacement
Cosa ti serve
  1. Palm m105 Display Screen Replacement, Display Screen: passo 1, immagine 1 di 1
    • Flip the protective cover open and pull it straight away from the device to release the two clips.
  2. Palm m105 Display Screen Replacement: passo 2, immagine 1 di 1
    • To remove the faceplate, locate the tab at the top of the device.
    • Lift the tab upwards with your finger.
    • The tab releases easily. Excessive force is not required.
  3. Palm m105 Display Screen Replacement: passo 3, immagine 1 di 2 Palm m105 Display Screen Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    T5 Torx Screwdriver
    $5.49
    • Using a T5 Torx screwdriver, remove the four screws located on the back of the device.
    • With the screws removed, the device is separated into two parts (the empty back cover and the back case holding the main components).
  4. Palm m105 Display Screen Replacement: passo 4, immagine 1 di 1
    • Be careful with this step. The motherboard and screen are attached by fragile cables.
    • Slowly lift the motherboard and the screen from the back case.
    • Gently hold the screen back so that you see the cables between it and the motherboard.
  5. Palm m105 Display Screen Replacement: passo 5, immagine 1 di 2 Palm m105 Display Screen Replacement: passo 5, immagine 2 di 2
    • Detach the screen from the motherboard by carefully pulling up on the three tabs.
    • Be careful. These tabs are fragile.
    • The motherboard and screen separate once the three tabs are released.
    • Recycle the old screen.
Conclusione
Erik Thompson
Membro da: 10/04/11
31 Reputazione
5 Guide realizzate
UW Stout, Team 1-3, Zhou Fall 2011 Membro di UW Stout, Team 1-3, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G3
4 Membri
7 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 14
Tutti i Tempi: 867
