Salta al contenuto principale
Palm TX Power Button Replacement
Cosa ti serve
  1. Palm TX Power Button Replacement, Back Panel: passo 1, immagine 1 di 2 Palm TX Power Button Replacement, Back Panel: passo 1, immagine 2 di 2
    • Orient the device so that the display faces forward.
    • Remove the stylus from the right side.
  2. Palm TX Power Button Replacement: passo 2, immagine 1 di 1
    • Turn over the device so that the back panel faces forward.
    • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
  3. Palm TX Power Button Replacement: passo 3, immagine 1 di 2 Palm TX Power Button Replacement: passo 3, immagine 2 di 2
    • Rotate the device so that the display faces forward.
    • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
    • Pry along the crevice to loosen the back panel.
    • Repeat this process for the right side.
  4. Palm TX Power Button Replacement: passo 4, immagine 1 di 2 Palm TX Power Button Replacement: passo 4, immagine 2 di 2
    • Carefully pry the back panel to open the device.
    • Be careful not to break the wire that connects the battery pack to the motherboard.
    • When reassembling, snap the back panel back into place and then insert the top cover.
  5. Palm TX Power Button Replacement: passo 5, immagine 1 di 2 Palm TX Power Button Replacement: passo 5, immagine 2 di 2
    • Use a plastic opening tool to peel the battery pack from the back panel.
    • The battery pack is glued to the back panel so removing it may require considerable effort.
  6. Palm TX Power Button Replacement, Battery Pack: passo 6, immagine 1 di 2 Palm TX Power Button Replacement, Battery Pack: passo 6, immagine 2 di 2
    • Use a soldering iron to disconnect the battery wires from the motherboard.
    • For soldering instructions, you can view the Soldering Guide.
  7. Palm TX Power Button Replacement, Motherboard: passo 7, immagine 1 di 2 Palm TX Power Button Replacement, Motherboard: passo 7, immagine 2 di 2
    • Pull straight up on the ribbon cables located on the bottom right of the motherboard to disconnect them.
  8. Palm TX Power Button Replacement: passo 8, immagine 1 di 2 Palm TX Power Button Replacement: passo 8, immagine 2 di 2
    • Lift the mother board out of the device.
    • A weak adhesive attaches the motherboard to the device.
    • The red wire in the picture will not be attached to your device at this point.
  9. Palm TX Power Button Replacement, Power Button: passo 9, immagine 1 di 1
    • Flip the motherboard so that the black rubber cover faces upward. The power switch is in the top right corner.
    • Remove the button with a soldering iron.
    • For soldering instructions, view the Soldering Guide.
Conclusione
Cal Poly, Team 1-15, Amido Winter 2011 Membro di Cal Poly, Team 1-15, Amido Winter 2011
CPSU-AMIDO-W11S1G15
4 Membri
9 Guide realizzate
2Commenti sulla guida
what do i do after i remove said button?
Dewm - Replica
what do i do aftert i desolder the button
Dewm - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 16
Tutti i Tempi: 3,515
