Salta al contenuto principale
Palm TX Buttons and Connector Assembly Replacement
Cosa ti serve
  1. Palm TX Buttons and Connector Assembly Replacement, Back Panel: passo 1, immagine 1 di 2 Palm TX Buttons and Connector Assembly Replacement, Back Panel: passo 1, immagine 2 di 2
    • Orient the device so that the display faces forward.
    • Remove the stylus from the right side.
  2. Palm TX Buttons and Connector Assembly Replacement: passo 2, immagine 1 di 1
    • Turn over the device so that the back panel faces forward.
    • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
  3. Palm TX Buttons and Connector Assembly Replacement: passo 3, immagine 1 di 2 Palm TX Buttons and Connector Assembly Replacement: passo 3, immagine 2 di 2
    • Rotate the device so that the display faces forward.
    • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
    • Pry along the crevice to loosen the back panel.
    • Repeat this process for the right side.
  4. Palm TX Buttons and Connector Assembly Replacement: passo 4, immagine 1 di 2 Palm TX Buttons and Connector Assembly Replacement: passo 4, immagine 2 di 2
    • Carefully pry the back panel to open the device.
    • Be careful not to break the wire that connects the battery pack to the motherboard.
    • When reassembling, snap the back panel back into place and then insert the top cover.
  5. Palm TX Buttons and Connector Assembly Replacement: passo 5, immagine 1 di 2 Palm TX Buttons and Connector Assembly Replacement: passo 5, immagine 2 di 2
    • Use a plastic opening tool to peel the battery pack from the back panel.
    • The battery pack is glued to the back panel so removing it may require considerable effort.
  6. Palm TX Buttons and Connector Assembly Replacement, Battery Pack: passo 6, immagine 1 di 2 Palm TX Buttons and Connector Assembly Replacement, Battery Pack: passo 6, immagine 2 di 2
    • Use a soldering iron to disconnect the battery wires from the motherboard.
    • For soldering instructions, you can view the Soldering Guide.
  7. Palm TX Buttons and Connector Assembly Replacement, Motherboard: passo 7, immagine 1 di 2 Palm TX Buttons and Connector Assembly Replacement, Motherboard: passo 7, immagine 2 di 2
    • Pull straight up on the ribbon cables located on the bottom right of the motherboard to disconnect them.
  8. Palm TX Buttons and Connector Assembly Replacement: passo 8, immagine 1 di 2 Palm TX Buttons and Connector Assembly Replacement: passo 8, immagine 2 di 2
    • Lift the mother board out of the device.
    • A weak adhesive attaches the motherboard to the device.
    • The red wire in the picture will not be attached to your device at this point.
  9. Palm TX Buttons and Connector Assembly Replacement, Display: passo 9, immagine 1 di 1
    • Orient the device sideways, as shown in the picture.
    • Lightly push the front of the display to separate it from the front panel.
    • The battery in the picture will not be attached to the device at this point.
  10. Palm TX Buttons and Connector Assembly Replacement, Buttons and Connector Assembly: passo 10, immagine 1 di 1
    • Use a T5 Torx screwdriver to remove the 7.75mm screws at the bottom of the device.
    • It may take some manipulation to remove the screws.
  11. Palm TX Buttons and Connector Assembly Replacement: passo 11, immagine 1 di 1
    • Lift the button and connector assembly from the front panel.
Conclusione
Cal Poly, Team 1-15, Amido Winter 2011 Membro di Cal Poly, Team 1-15, Amido Winter 2011
CPSU-AMIDO-W11S1G15
4 Membri
7 Guide realizzate
Un commento
Where can you buy one of these?
Sean Madawala - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,651
