Salta al contenuto principale
PSKONTORORA LBER-P4-05 Vibration Motor Replacement
Cosa ti serve
  1. PSKONTORORA LBER-P4-05 Vibration Motor Replacement, Rear Case: passo 1, immagine 1 di 3 PSKONTORORA LBER-P4-05 Vibration Motor Replacement, Rear Case: passo 1, immagine 2 di 3 PSKONTORORA LBER-P4-05 Vibration Motor Replacement, Rear Case: passo 1, immagine 3 di 3
    • Remove the two 10 mm Phillips #1 screws that secure each of the handle grips.
    • Pull off the handle grips.
  2. PSKONTORORA LBER-P4-05 Vibration Motor Replacement: passo 2, immagine 1 di 3 PSKONTORORA LBER-P4-05 Vibration Motor Replacement: passo 2, immagine 2 di 3 PSKONTORORA LBER-P4-05 Vibration Motor Replacement: passo 2, immagine 3 di 3
    • Remove the four 9 mm Phillips #1 screws that secure the rear case.
    • Lift off the rear case from the controller.
  3. PSKONTORORA LBER-P4-05 Vibration Motor Replacement, Battery: passo 3, immagine 1 di 3 PSKONTORORA LBER-P4-05 Vibration Motor Replacement, Battery: passo 3, immagine 2 di 3 PSKONTORORA LBER-P4-05 Vibration Motor Replacement, Battery: passo 3, immagine 3 di 3
    • Use blunt tweezers to pull the white battery motherboard connector directly out of its port.
    • Gently peel the battery off of the motherboard.
    • Be sure not to bend or puncture the battery during removal.
  4. PSKONTORORA LBER-P4-05 Vibration Motor Replacement, Joystick Covers: passo 4, immagine 1 di 1
    • Remove the two 7 mm Phillips #1 screws that secure the motherboard.
  5. PSKONTORORA LBER-P4-05 Vibration Motor Replacement: passo 5, immagine 1 di 2 PSKONTORORA LBER-P4-05 Vibration Motor Replacement: passo 5, immagine 2 di 2
    • Flip up the black ZIF locking flap that secures the touchpad ribbon cable on the top-right edge of the motherboard.
    • Use tweezers or your fingers to gently disconnect the touchpad ribbon cable.
    • Lift the motherboard up and out.
  6. PSKONTORORA LBER-P4-05 Vibration Motor Replacement: passo 6, immagine 1 di 2 PSKONTORORA LBER-P4-05 Vibration Motor Replacement: passo 6, immagine 2 di 2
    • Use your fingers to pull the joystick covers directly up and off the modules.
    • Clean or replace the joystick covers as necessary.
  7. PSKONTORORA LBER-P4-05 Vibration Motor Replacement, Vibration Motor: passo 7, immagine 1 di 3 PSKONTORORA LBER-P4-05 Vibration Motor Replacement, Vibration Motor: passo 7, immagine 2 di 3 PSKONTORORA LBER-P4-05 Vibration Motor Replacement, Vibration Motor: passo 7, immagine 3 di 3
    • Prop the motherboard up with a non-flammable material.
    • Carefully desolder each of the vibration motor motherboard connections.
    • Take note of which wires belong where.
    • Be sure to solder in a well-ventilated area and take appropriate safety precautions.
    • Remove the vibration motors.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 22
Tutti i Tempi: 307
