Salta al contenuto principale
PDP Rematch Top Left and Right Button(s) Replacement
Cosa ti serve
  1. PDP Rematch Top Left and Right Button(s) Replacement, Faceplate: passo 1, immagine 1 di 2 PDP Rematch Top Left and Right Button(s) Replacement, Faceplate: passo 1, immagine 2 di 2
    • Grip one side of the controller firmly.
    • Insert an opening pick into the crease between the faceplate and the body of the controller.
    • Once the pick creates a gap in the crease, gently insert another pick into a different section of the crease.
    • Carefully move the picks along the controller's crease line until you hear a popping sound.
    • Gently lift off the faceplate by hand.
  2. PDP Rematch Top Left and Right Button(s) Replacement: passo 2, immagine 1 di 2 PDP Rematch Top Left and Right Button(s) Replacement: passo 2, immagine 2 di 2
    • Remove the 8 mm screws from the hard cover using a JIS #00 screwdriver.
    • Since the screws have been removed, avoid shaking or moving your controller too much to prevent other buttons from falling out.
  3. PDP Rematch Top Left and Right Button(s) Replacement: passo 3, immagine 1 di 2 PDP Rematch Top Left and Right Button(s) Replacement: passo 3, immagine 2 di 2
    • Gently lift off the hard cover with your hand; it should not need much force.
  4. PDP Rematch Top Left and Right Button(s) Replacement, Top Left and Right Buttons: passo 4, immagine 1 di 2 PDP Rematch Top Left and Right Button(s) Replacement, Top Left and Right Buttons: passo 4, immagine 2 di 2
    • Remove the back panel by pulling it away from the front.
    • Disconnect the cable by squeezing the two sides while pulling the cable away from the motherboard.
  5. PDP Rematch Top Left and Right Button(s) Replacement: passo 5, immagine 1 di 2 PDP Rematch Top Left and Right Button(s) Replacement: passo 5, immagine 2 di 2
    • Touch the hot tip of the soldering iron to the first solder connecting the buttons to the motherboard until the solder melts.
    • Repeat this for the next solder. Verify solders have detached from motherboard.
    • Be careful of the hot soldering tip.
  6. PDP Rematch Top Left and Right Button(s) Replacement: passo 6, immagine 1 di 2 PDP Rematch Top Left and Right Button(s) Replacement: passo 6, immagine 2 di 2
    • When the solder has completely melted, flip the controller and gently pull the wire free from the motherboard.
    • Repeat for the other black wire.
Conclusione
GraceGrubbs
Membro da: 01/24/24
147 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 24
Tutti i Tempi: 300
